Tractor Talk Discussion Forum
toro snowblower 828-powershift stuck in reverse
bob44
12-08-2005 16:12:46
I have a toro 828-powershift. It's stuck in reverse. The shift lever moves through the positions ok. It just won't get out of reverse. any suggestions ?
RWK in WI
12-09-2005 17:31:12
 Re: toro snowblower 828-powershift stuck in revers in reply to bob44, 12-08-2005 16:12:46
I haven't had a "Toro" apart, but most snowblowers shift by moving a disk along a hex shaft so it meets the drive plate at various positions. Most likely the disk is either rusted to the hex shaft or stuck to the dirve plate.
Tip the machine up on its auger, remove the cover from the bottom ( and maybe part of the back ) and fix the problem. I hope this helps you.
