Tractor Talk Discussion Forum
oil blow massey 135
dantanner
12-10-2005 13:55:37
Hi.HAVE A MASSEY I35 WHICH BLOWS OUT OIL WHEN YOU PULL OUT THE DIP STICK.CHECKED THE BREATHER PIPE OUTLET THERE IS NO OIL BLOW THERE,SHOULD THERE BE A LOT OF PRESSURE BLOWING OUT AT THIS PIPE.DOES ANONE KNOW WHATS WRONG?TRACTOR IS VERY EASY TO START AND IS RUNNING WELL WITH NO BLACK SMOKE COMING OUT THE EXAUST.WHAT WOULD MIGHT HAPPEN IF I JUST LEFT IT AS IT IS?
dantanner
12-11-2005 05:19:48
 Re: oil blow massey 135 in reply to dantanner, 12-10-2005 13:55:37
Thanks guys for takeing the time to help.Disconected the breather pipe at the rocker cover,tried the wire it dosent go in to far maybe a couple of inches,the pressure of air isint gret out of that pipe should it be?I have a 35 as well with a engine rebuild it dosent blow any oil out the removed dip stick while running.
mowr
12-10-2005 18:07:17
If the breather's not restricted, I think your tractor is just telling you that there is plenty of lubricating oil moving around at that part of the engine and if you take the cap off when it's running, you might get sprayed.
BobMo
12-10-2005 14:57:11
Dan, some blowby is normal so you have something restricting it and I suspect its just as Farrview says. Clean out your blowby tube and see if that doesn't do the job..
farrviewsouth
12-10-2005 14:28:58
sounds like the breather pipe has plugged up over the years with crud. Try running a piece of fence wire up it to clean
Del MI.
12-10-2005 18:00:26
 Re: oil blow massey 135 in reply to farrviewsouth, 12-10-2005 14:28:58
If it is running when you pull out the dip stick any tractor will blow out oil. Only check the oil level when the tractor is not running. If this is not the case excuse me ,I am back to lurking.
Del MI.
dantanner
12-12-2005 12:23:17
 Re: oil blow massey 135 in reply to Del MI., 12-10-2005 18:00:26
Someone sugested a ring or gasket problem,any thoughts.What would if i just left it.
