Tractor Talk Discussion Forum
HS huber piston needed
mike 28 OCH
12-11-2005 09:59:05
I need a piston for a CHS waukesha in a Huber HS 4.75 bore
Glenn H.
02-07-2006 09:21:27
 Re: HS huber piston needed in reply to mike 28 OCH, 12-11-2005 09:59:05
I'm just wondering what shape the manifold is in(cracked ect.)? Every early all fuel Huber manifolds i have seen have cracks in them as well as the two i have.
RAB
12-11-2005 23:02:17
If it is the same as the Oliver 443 Waukesha, it should not be a problem.
Regards, RAB
Lee W
12-11-2005 15:31:15
I am sure this is the same piston as the 99 or 28-44 Oliver, I probably have one if you want me to check for you, I just don't remember what kind of shape it is in.
mike28och
12-13-2005 17:45:16
 Re: HS huber piston needed in reply to Lee W, 12-11-2005 15:31:15
I would greatly appreciate your looking. I also appreciate the info;~mike~
RAB
12-11-2005 14:41:05
Hi,
Haven"t a clue as to actual engine but here are a few questions - the answers to these might help you get a better response.
Cast iron or aluminium?
Small end diameter?
Piston height over gudgeon pin?
Flat top, dome or concave?
Anything else that might be special?
Could engine be bored for a larger standard size?
An alternative might be easily available.
I am surprised at the reply from Jerk. "I need", to me, means you would be prepared to pay for one and wouldn"t expect it to be free?
Regards, RAB
Jack Jones
12-11-2005 10:33:57
I have three but I'm not giving any of them to you. Jerk.
