Tractor Talk Discussion Forum
jd40
nhboyd
12-11-2005 15:58:49
i have a jd40 i am having problem keeping it running. it will idle but when you put a load on it you have to run it with the choke most of the way closed. i rebuilt the carb but it didn't help. any ideas?
old
12-11-2005 16:42:25
 Re: jd40 in reply to nhboyd, 12-11-2005 15:58:49
Well either your fuel line is clogged or you didn't get the carb cleaned up god enough. Carbs can be tricky sometimes and can take a few tries to get them to work as they should.
