Tractor Talk Discussion Forum
bubble top or cone top piston for a 730 jd diesel
jimmy fletcher
12-11-2005 17:48:32
I am replacing my piston in my 730 jd and a man is trying to sell me NOS piston with rings and pins. They are bubble top pistons. But I notice when I was taking my old pistons out, they are cone top piston. Is this man selling me the wrong pistons?
Mike M
12-12-2005 04:42:53
 Re: bubble top or cone top piston for a 730 jd die in reply to jimmy fletcher, 12-11-2005 17:48:32
The pistons should have a part number so you can track down exactly what they fit.
buickanddeere
12-11-2005 18:22:01
The 730 and part or all of the 720's used narrow spray pattern injector tips with six orifices. 13 mm injection pumps too. And the piston had a narrow but deep combustion chamber. I would have to check the parts book to be certain The 70, 80 and early 820's used a five hole, wide spray injector tip. And 10mm injection pumps. The piston had a shallow/wide combustion chamber. Some vicious fights and flaming have occurred during discussions about using the wide pistons/narrow injectors or wide injectors and narrow pistons. Those pistons would have to be pretty cheap and you should have somebody with a 70D looking for original pistons to sell them to.
