Tractor Talk Discussion Forum
Horsepower 70 series Detroit Diesel
IronHorse
12-14-2005 06:48:01
Can you tell me the Horsepower of a 4-71 Detroit Diesel? Engine Number 4A-55743
buickanddeere
12-14-2005 16:37:28
 Re: Horsepower 70 series Detroit Diesel in reply to IronHorse, 12-14-2005 06:48:01
Depends some if it's an "S" or and "N" engine. 45 injectors would make about 90HP at 1800 rpms. 70 injectors at 2300rpms would make about 170HP.
Jon Hagen
12-14-2005 07:20:17
You mean 71 series. Depending on equipment and rpm,a non turbo 71 will make about 40 hp per hole,or 160 hp for a 4-71.
rpg52
12-15-2005 13:53:57
 Re: Horsepower 70 series Detroit Diesel in reply to Jon Hagen, 12-14-2005 07:20:17
Hi,
Seems like it all depends, (on version, rpm, etc.). The early -71's were 2 valve, later with 4 valves, then with turbo. The earlier versions made about 25+/- hp/cylinder, depending on the rpm the hp was measured. I have an old 2 valve 3-71 that states "65 hp @ 1600 rpm" on a plate on the engine. I think it makes 75-80+ at closer to 2000 rpm. The turbo version w/4 valves is listed at 113 hp, or about 38 hp/cylinder, likely measured at ~2100 rpm. Changing the injectors to higher volume could alter any of this of course.
Ray
