Tractor Talk Discussion Forum
stripping insulation from scrap wire
BSer
12-17-2005 17:00:09
I have a chance to get a LOT of insulated aluminum wire.Stripping by hand is slow and could be dangerous. does anyone have or know of a machine that could speed it up? I cn"t buy a new machine because my source may dry up.
Leland
12-18-2005 22:45:53
 Re: stripping insulation from scrap wire in reply to BSer, 12-17-2005 17:00:09
I have saw guys cut a old tank in 1/2 start a roaring fire and throw the alum inthere and the melted alum would run out the bottom thru a small hole and they let it run into large pie pans and made ingonts .
BSer
12-18-2005 03:28:38
I don't want to urn it. It's worth $.05 per pound more unburnt;and the insulatin is worth $.15 per pound. The tool posted is exactly what I need. Thanks guys!!!
big jt
12-17-2005 23:40:05
Find a scrapper with a smelter. You will probably need to do a "in kind" share type of thing but will be worth it. Ingots bring a lot more than bare wire.
Also overhead triplex has steel in it. Smelting is the easy way to separate.
jt
Dixieland
12-17-2005 18:50:09
You might give this wire stripper a try.
Drill
12-18-2005 09:32:55
 Re: stripping insulation from scrap wire in reply to Dixieland, 12-17-2005 18:50:09
Looks like a real handy machine, Dixieland, but a little pricey. I burn off most of the copper wire I have, but like it was mentioned, aluminum wire has a tendancy to melt. Copper prices have really gone up lately, but it is hard to find any, everyone is holding on to it.
doogdoog
12-18-2005 12:32:00
 Re: stripping insulation from scrap wire in reply to Drill, 12-18-2005 09:32:55
Aloha, I hope I am not the cause by hoarding pennies! LOL
Mahalo,
doogdoog
Erran
12-17-2005 17:20:04
Burn it off. We do that all the time.
Tim B from MA
12-17-2005 20:37:54
 Re: stripping insulation from scrap wire in reply to Erran, 12-17-2005 17:20:04
If you burned aluminum wire, wouldn't you end up with a puddle of aluminum mixed with ash and unburned pieces of insulation?
steveormary
12-17-2005 20:56:38
 Re: stripping insulation from scrap wire in reply to Tim B from MA, 12-17-2005 20:37:54
Probably not. Go ahead and burn it off.
steveormary
