Tractor Talk Discussion Forum
Sears Custom 7 Engine
Mmatto99
12-17-2005 19:40:58
I have a sears custom 7, the engine seems to be getting tired. Is there a new replacement engine that can be put in that the clutch pedal would hook up too.
lucasss
12-18-2005 18:15:58
 Re: Sears Custom 7 Engine in reply to Mmatto99, 12-17-2005 19:40:58
i dont know of another engine with the mountings for the clutch pedal . allthough a custom 6 or 8 engine will fit.those engines have a cast iron bore and can be rebuilt.the 10 and 12 hp hh100 and hh120 sears engines had the same clutch pedal mountings too .i rebuilt my custom 7 in 82 and used it 20 years more.i bored it.it still runs great but i got a woods zero turn i use mostly now. there is a tecumseh rep at the perr.com forum named tecumpman,you could direct your question there to him,he may know something else. lucas
Dale in Ar.
12-17-2005 20:42:23
My Sears has a brigs engine on it and it has a pulley for a belt.This belt runs back through to the transmission.The clutch is a idle wheel that runs on the belt to loosen or to tighten.The clutch is not connected to the motor.I changed my old motor out because it was beyound repair and I used a 5hp. Brigs that came off of a garden tiller.Hope this all helped to some degree.My Sears is a Custom 7 but I have yet to see another like it.I've seen some close to it but not exactly like it.Mine may be odd or something else.
