Tractor Talk Discussion Forum
OT. Harmonic balancer
Butcher
12-18-2005 09:33:50
I'll try to make this short. 1987 chevy truck. 454cid. Balancer completly spit out the rubber between the inner hub and outer ring. Question, will I do more damage driving it 5 miles to get it to heated shop for repair? Thanks.
Allan in NE
12-18-2005 12:32:00
 Re: OT. Harmonic balancer in reply to Butcher, 12-18-2005 09:33:50
Butch,
Cross your fingers and go.
Try to stay away from 1500 engine rpm as that is the speed where the flex is the greatest and where you run the risk of breakin' the crank.
Allan
old
12-18-2005 11:33:02
Probably will not hurt any thing as long as the water pump etc will still turn. A lot of those are set up so if it comes apart you also loose your V belts.
