Tractor Talk Discussion Forum
O.T. - Burning old siding in woodstoves
CB in central N
12-19-2005 05:37:00
Greetings to all and Merry Christmas.
This one is probably best directed to the older set, although anyone"s advice would be appreciated. This past summer I stripped old wood siding from a couple of walls in my barn (there wasn"t much left) and resided with new wood siding. The barn dates back to before 1900, but the siding was probably last replaced in the 1950"s (just a guess). This winter I decided to cut up the scrap siding to use as kindling (I have a woodstove and an indoor wood boiler). When I started cutting it, I thought I smelled that all-too-familiar smell of creosote. If that"s the case, I definitely wouldn"t want to burn it.
My question is: was it standard practice to coat or otherwise treat wood siding with creosote back in those days? I thought some of the wood gave off that smell and some didn"t. Would the creosote have been brushed on after the siding was purchased or did it come pre-treated?
Any advice would be appreciated. I apologize for the O.T. post.
john17
12-19-2005 07:59:43
 Re: O.T. - Burning old siding in woodstoves in reply to CB in central NY, 12-19-2005 05:37:00
Could it have had tar paper next to it? That may explain the smell. I know on the older buildings they used a lot of tarpaper. Also known as felt in other parts of the country. Hope this helps. JohnG
Glen in TX
12-19-2005 06:46:03
If it was just a old home made stove in shop or barn with a short straight chimney you can clean easily and you could can get it very hot that would be better to burn it in than a stove in house. You don't want it coating boiler pipes for sure. In town you may get complaints from neighbors burning trash stuff in stove too. Actually many crafts people will pay good money for old barn siding wood and even old fence boards to make things with because it has that aged look. I don't like it to make things with because it's hard on blades and tools dulling them.
Jay (ND)
12-19-2005 06:16:12
I cant answer that question, but I would be very careful as a lot, if not all, of the older paint was lead based.
Richard H.
12-19-2005 05:54:17
Would not surprise me none, before the dangers of creosote were known people used it to deter termites and such.
