Tractor Talk Discussion Forum
Year Around Cab Heater
Robhkent
12-19-2005 16:46:17
Help!! Looking for a twin fan set and motor for a Y A Cab model 205. ..Ok really I am wondering if anyone has replaced this unit with anything out of a car or truck, something easier to find?? Also, did year around get bought out or are are they defunct?
R. John Johnson
12-20-2005 06:38:22
 Re: Year Around Cab Heater in reply to Robhkent, 12-19-2005 16:46:17
Sticks in my head I say that fan unit in T.H.E.Company's catalogue. You might want to give them a try.
John
ohio dick
12-19-2005 21:14:47
Mack truck model MR uses a moter with two fans in cab heater. This may work in your application.
mdk
12-19-2005 19:13:57
Go to your local heavy equipment dealer.They usually have add on cab heaters.
paul
12-19-2005 18:19:58
Y-a-R offer some parts yet, they are located about 30 miles from me, they are into big corn stoves now a days. But still support their older products.
For something completely different, Northern Tool has a simple cab heater deal in their catalog, if you wish to start over....
--->Paul
acmfmh
12-19-2005 18:00:54
Some parts are available from year-a-round. I will try to attach the link.
http://www.year-a-round.com/cab_Price_list.html
Robhkent
12-19-2005 18:40:40
 Re: Year Around Cab Heater in reply to acmfmh, 12-19-2005 18:00:54
Thanks!!
I did a google search for year around cab.. did I get that site. NO.!
Thanks again
Rob
Thanks also Paul!
RustyFarmall
12-19-2005 16:49:48
Rob, I think those are available somewhere, let me rattle my brain and see what I can come up with.
Robhkent
12-19-2005 16:53:35
 Re: Year Around Cab Heater in reply to RustyFarmall, 12-19-2005 16:49:48
Thanks Rusty, and hopefully as close as you are!
RustyFarmall
12-19-2005 17:05:14
 Re: Year Around Cab Heater in reply to Robhkent, 12-19-2005 16:53:35
No luck so far. Might have to wait until tomorrow and make some phone calls.
Robhkent
12-19-2005 17:08:41
 Re: Year Around Cab Heater in reply to RustyFarmall, 12-19-2005 17:05:14
Thanks I appreciate it. I have to remove the fan and motor from the heater, but it is all pretty stiff, and I never have any luck with this stuff. I may try Houcks over by Corning also.
Rob
RustyFarmall
12-19-2005 17:13:47
 Re: Year Around Cab Heater in reply to Robhkent, 12-19-2005 17:08:41
If Houcks don't have it, you are probably out of luck.
Robhkent
12-19-2005 17:36:57
 Re: Year Around Cab Heater in reply to RustyFarmall, 12-19-2005 17:13:47
I will call them tomorrow. If not looks like I will be taking it all apart and carefully cleaning and lubing everything
Thanks again
Harley
12-20-2005 08:06:31
 Re: Year Around Cab Heater in reply to Robhkent, 12-19-2005 17:36:57
Howdy Rob, Harley here. One time I wanted to heat the pickup bed with a shell I had on it and I just ran heater hoses back to an old pickup heater core,fan, and put a toggle switch on it. You could set that in the right hand corner of the cab, and I can tell you it will run you out of there. Maybe not factory, but about $8.00 from Afro-Engineering Inc. Harley
Quebec Red
12-20-2005 10:33:25
 Re: Year Around Cab Heater in reply to Harley, 12-20-2005 08:06:31
Put a new Hiniker cab on a new Hydro 70 in 1975. Aftr it was all connected properly and tractor working, the heater put out warm only air on a warm autumn day. Come evening and good bye heat. We we were never able to cure the problem. The dealer sold a bunch of 70s, 86s, 666s and 686s with those cabs. None heated well. They all received an excellent auxillary heater that was mounted where the left battery was. Almost all of these tractors were equipped with an 8D battery in a shop built box just below the LF cab corner and got 1 guage cables. This was done by the dealer amd was included in the price. Along with a properly plumbed 1500 Watt block heater(plumbed to heat the block, not the top of the motor as some people think they should) permitted these tractors to be good starters in this area.
