Tractor Talk Discussion Forum
Battery for 6V System
Wayne Nelson
12-22-2005 07:53:34
How many "Cold Cranking Amps" do I need for my 6V battery in 20 degree weather?
I have a 140 tractor.
John T
12-22-2005 11:08:35
 Re: Battery for 6V System in reply to Wayne Nelson, 12-22-2005 07:53:34
Wayne, in addition to and as important as the HIGHEST CCA RATED BATTERY THAT WILL PHYSICALLY FIT as posted below, use large Gauge Battery n Starter n Ground cables such as 0 or even 00 on 6 volt systems and have the ground cable attached to a main frame type bolt as opposed to any thin or rusty sheet metal enclosure, the closer to or on the starter as possible.
John T
mhb@ufe
12-22-2005 10:01:36
I use a New Holland F220 battery in my 48 8N. It has 625 cca and my tractor will start at 20 below here in Maine. I just replaced it this year after 7 years of service.
old
12-22-2005 08:54:59
As Jon has said you want the most CCA that you can find in a bayyerty that will fit in to the place you have to put it in. There are other thing to think about also. Where you park the tractor and how often you use it.
Jon Hagen
12-22-2005 08:40:38
Short answer is,as many as you can fit into the battery compartment.
