Tractor Talk Discussion Forum
Engine swap
Perry L Estal
12-24-2005 16:09:07
Has any one put any other engine in a WD allis I would like to put in a Passinger car ingine I have a friend in a machine shop putting a 305 chevy in a D17 looks like he might make it fly when he gets done or should I say work I want to stay with a four clyinder
cdmn
12-25-2005 21:27:32
 Re: Engine swap in reply to Perry L Estal, 12-24-2005 16:09:07
I've seen both Chev OHV and Chrysler flathead sixes in WCs and WDs. I'd like to try a 300 Ford six. It has same bore and stroke as a WD. You'd need to move radiator to forward position and get a hood from a diesel. You'd also need a belt-drive governor, such as used on a Versatile swather. For best work, you might need a special grind high torq camshaft, but that can wait. Otherwise, you could look over engines from other tractors, such as Massey, Oliver, Farmall, etc.
Chris Brown
12-24-2005 17:43:25
I have a 262 ci engine from an a2 combine I have been saving to put in WD. If you keep the rpm high it"ll make 75 hp.You need a few parts from a WD45 diesel to make it fit.
big jt
12-24-2005 16:26:43
I would suggest a late D17 gas engine, 170 gas engine or the considerably more available E Gleaner engine. All of these with the possible exception of the 170 are drop ins. Same basic block as your WD engine.
E Gleaner will need some work on the governor as some had a single speed governor.
jt
