Tractor Talk Discussion Forum
serial nr.
Diederik
12-28-2005 08:04:52
Is somebody able or in the posession of the good books to help me find some information about some numbers on my fordson major block. H27B , S 139671.
In cyl.head I found EIADDN 6050F J . Also in head: J8/B DDNF4. What is the meaning of the word "Enfo" in almost all the parts on my engine???? Mayday mayday please help me.
Majorman
12-28-2005 08:48:34
 Re: serial nr. in reply to Diederik, 12-28-2005 08:04:52
H27B = June 27th 1958. 139671 is June 1956. Could be this tractor has been built from parts of other tractors. Or have you mis-read the letter "B"? It should be "Z". The 139 number is the serial number for 1956 up to September that year.
The DDN numbers and the E1ADDN numbers are just casting numbers and of no help. "EnFo" is the English Fordson emblem.
Try Oscars Fordson Site at fordson.freeweb.nl/home.htm
Diederik
12-29-2005 00:33:55
 Re: serial nr. in reply to Majorman, 12-28-2005 08:48:34
It was not mis-reading between B or Z. anyway, i only want to look for engine instruction book only because i have no tractor, this motor is installed in a boat!!and is driving an American Paragon hydraulique gearbox reduction 1/2. my Simms plungers are 7.5mm and pushrods 299.7mm.I found this information in oscar fordson side. Mayby ican decide that mine is a MarkII ?? the power is 61hp, and in another information, i heard that the same 4-cyl.engine is also constructed with power of 41hp. In that case, is it only the fuelpump who makes the diiferance in power??? My max. revolution is 2200rev/min.and the setting of feulpump is 19°before TDC. May i advance this a little and how much? If you have plenty time, can you also answer these questions? By this way, i want to wish all fordson-brother and sisters a very succes-full 2006!!!
Diederik
12-28-2005 12:24:16
Thank you very much for your quick answer.
Bob
12-28-2005 08:08:56
Only part I can help with, "enfo" = English Ford.
