Tractor Talk Discussion Forum
what causes white smoke
Jrry
12-28-2005 08:29:41
My son called and said his car is blowing out white smoke. The temp where he is is around 60 so thats not the somke he's referring to. He said the car is running ok. the car has not run for a couple months. It was not smoking prior to then. Anyone have an idea
Doyle Alley
12-29-2005 05:23:57
 Re: what causes white smoke in reply to Jrry, 12-28-2005 08:29:41
Wait a minute before you start thinking about repairs. Yes, white smoke means water in the combustion chamber (like has been previously mentioned. However, you said the vehicle has been siting for several months. That water could be from excessive condensation in the gas tank. Add a can of water absorber and run all that gas out (as empty as you can) then fill with good fresh gas. If the white smoke stops, you've found your problem without spending a lot of money on unnecessary repairs.
Jrry
12-29-2005 05:48:42
 Re: what causes white smoke in reply to Doyle Alley, 12-29-2005 05:23:57
thanks Doyle, that is worth a try before spending money.
Jerry
Man who rides horse backw
12-28-2005 16:51:34
Means blanket is too close to fire, Ugh
Jim.UT
12-28-2005 13:55:54
Depending on where the white smoke is coming from, it could mean we have a new pope!
Jrry
12-29-2005 05:50:23
 Re: what causes white smoke in reply to Jim.UT, 12-28-2005 13:55:54
I think he needs the Pope to pray over this car. He just spent $1500 on it and now this.
thanks,
Jerry
Jim.UT
12-28-2005 13:57:22
 OOPS, sorry! Disregard previous post! in reply to Jim.UT, 12-28-2005 13:55:54
I forgot about the "no religion" policy of this board!
skipper
12-28-2005 09:47:46
Jerry it is doubtful that it is a rich fuel mixture. Normally fuel is black smoke, and white smoke is water condensing with the hot combustion temperatures and oil is more of a gray. IMHO
Skipper
Jrry
12-28-2005 09:54:54
 Re: what causes white smoke in reply to skipper, 12-28-2005 09:47:46
thanks Skipper. I was guessing it was the fuel mixture since there no water in the oil. Oil is still black. I backed off on the idea it was a fuel mixture when he told me how bad it was smoking.
thanks, Jerry
dhermesc
12-28-2005 08:58:01
Blown head gasket or a rich fuel mixture. I was sure my Mercury had a blown head gasket (4.6 engine), lots of white smoke and I literally had water running out the exhaust when it sat an idled, but the computer needed to be reset, mileage immediately went from 15-16 to 28 on the highway.
Jrry
12-28-2005 09:03:29
 Re: what causes white smoke in reply to dhermesc, 12-28-2005 08:58:01
Rich fuel mixture was what I first told him but he said it was smoking really bad so i figured that wasn't the problem. Recently had the head redone so maybe the head gasket was no good. thanks, Jerry
Allan in NE
12-28-2005 08:50:59
Jrry,
Ford 3.8 engine?
Allan
Jrry
12-28-2005 09:00:14
 Re: what causes white smoke in reply to Allan in NE, 12-28-2005 08:50:59
Allan, it is a Mit. Eclipse. He just had the head redone but it wasn't smoking when he got it out of the shop but now it is. I think Old is right and the head gasket was defective that was put on recently.
thanks, Jerry
Allan in NE
12-28-2005 09:12:38
 Re: what causes white smoke in reply to Jrry, 12-28-2005 09:00:14
Jerry,
Tell him to stand behind it while its running. Should be able to smell the anti-freeze if that is what it is.
Very distinctive "sweeet" smell.
Allan
old
12-28-2005 08:38:05
Most of the time white smoke is water/antifreeze getting in to the cylinders. He may have a cracked head and or a bad head gasket. Has he at any time over heated the engine?? If so with the newer engines he probably cracked the head if/when he did.
Jrry
12-28-2005 09:04:56
 Re: what causes white smoke in reply to old, 12-28-2005 08:38:05
Old, that's probably the problem. He recently had the head redone so that probably is the culpret. thanks, Jerry
old
12-28-2005 10:14:02
 Re: what causes white smoke in reply to Jrry, 12-28-2005 09:04:56
Sounds like it was put on right and or turqued down the right way. Or the head might be warped even.
