Tractor Talk Discussion Forum
40-41 co-op b2jr
sharvey
12-29-2005 13:15:51
I am still looking for some help with any info on my co-op. I am not sure where to locate info on engine,transmission, serial #s, ect. Anything you could help me with would be appreciated.
jazinn
04-10-2006 19:32:51
 Re: 40-41 co-op b2jr in reply to sharvey, 12-29-2005 13:15:51
Sharvey, Did you ever decide for sure that your tractor was assembled in the Arthurdale plant? My grandfather worked at the plant there. We have not been able to locate any documintation showing what exact tractors were assembled here or what the serial #'s were.
Leroy
12-31-2005 14:21:50
On your Coop you asked for information, well if your tractor actually was made in West Virginia the national Cockshutt Club would be interested in talking with you because as they say "Numbering on the West Virginia version is unkowen as no specific tractors can be traced to the West Virginia plant." And that is for the No. 2, not a B2 or a B2jr. The B2 jr had a 4-cylinder Continental Model 41 L-head 162.4 CU in engine with a 3 7/16" bore and 4 3/8" stroke rated at 33.4 brake HP at 1500 rpm, 3,100# and had a Silver King 4 speed transmission and rear end and the engine also was the same as the Silver King and only 66 B-2Jrs were made. Now the B-2 was made to start with a 201 cu in Chrysler Indrustrial L-head 6 cylinder engine and a 4 speed transmission on 38" rear wheels. The B-3 had a Chrysler 242 cu in 6 cylinder engine and was only built for a short while till the 242" was offered in the B-2 by moving the rear motor mount 2" back and shortning the drive shaft, and all B-2, B-3 and B-2Jrs were built in Shelbyville, Ind. and most were built in 1941. If your tractor actually was built in West Virginia could it actually be a No. 2 with 28" rear wheels and the same engine? All this information is in the book "Cockshutt, the complete story" compiled by the International Cockshutt Club Inc. and the club address is, International Cockshutt Club, Contact; Lynn Harold Vernon, 168 Garland Line Road, Dover-Foxcraft, ME 04426. (207)564-7001. email; Ivernon@midmaine.com
sharvey
12-31-2005 14:41:26
 Re: 40-41 co-op b2jr in reply to Leroy, 12-31-2005 14:21:50
Now I need to figure out if it has a 201 or 242 chrysler 6 cyl. I don't know how to decipher those serial#s either!
J. Schwiebert
01-01-2006 12:27:55
 Re: 40-41 co-op b2jr in reply to sharvey, 12-31-2005 14:41:26
Do you have the pan off? The 201 Chrysler is different. I have a friend who knows, but I think he went to Florida. Find me on the hpoca web site and I will talk to you too. Happy New year.
sharvey
12-31-2005 14:34:44
Thanks so much...I am learning alot. I just assumed it was made in Arthurdale, west Virginia from the literature I have found. I don't know much, but thanks to everyone out there I am learning! I have ordered the Cockshutt book!Thanks again!
larry from maryland
12-29-2005 14:50:01
It should have a silverking trans and rear,with a continential engine.The rest is made to match the rest of the co-op line.Look for CWC on the engine block.A couple good pictures would be a big help.
sharvey
12-29-2005 16:36:23
 Re: 40-41 co-op b2jr in reply to larry from maryland, 12-29-2005 14:50:01
It has a chrysler flat head 6 cyl. I know it was made in West Virginia.
larry from maryland
12-30-2005 09:14:30
 Re: 40-41 co-op b2jr in reply to sharvey, 12-29-2005 16:36:23
Then its a B2 not a jr.Does it look like the one in the tractor photos on the left of this page?
sharvey
12-30-2005 12:29:14
 Re: 40-41 co-op b2jr in reply to larry from maryland, 12-30-2005 09:14:30
I do know it is a b2jr from pictures I have seen..I cannot access the pictures you are refering to. I have never seen such a huge rearend,(pig) before not sure what it is from.Thanks
larry from maryland
12-30-2005 13:09:12
 Re: 40-41 co-op b2jr in reply to sharvey, 12-30-2005 12:29:14
The hoods and grills on these co-ops are lookalikes.The B2jr has a 4 cylinder contential engine and the brake pedals are behind the axel.The B2 has a 6 cylinder chrysler engine 201ci,brake pedals just in front of the axel.Looking at pictures from the front it would be hard to tell them apart.
sharvey
12-31-2005 05:31:57
 Re: 40-41 co-op b2jr in reply to larry from maryland, 12-30-2005 13:09:12
I had no idea that there were 2 models...everything that I have seen (not much) has stated that there was only the b2jr w/chrysler 6cyl. Thanks so much for that info, I had no idea.Anything else you could share on the b2 would be of great help,and any publications that you know of on the subject would be great!
Thanks so much!
