Tractor Talk Discussion Forum
12 volt hydraulic system on tractor
RLH
12-31-2005 16:41:48
Has anybody ever put a 12 volt pump and resivor on a tractor with success tell me about it thanks in advance
smokieborde
01-04-2006 13:54:09
 Re: 12 volt hydraulic system on tractor in reply to RLH , 12-31-2005 16:41:48
put a car pump instead of generator
worked for me
put tractor on bat charger after use
a strong bat will last several days
espesly if you have a mag ingtion mine would last for weeks just starting motor
Turk
01-01-2006 20:43:58
I was thinking about using the pump and reservoir out of an old Tommy Lift to run a one way cylinder for a 3pt. on a Farmall A. I have one on an old pickup to run a hoist under the flatbed, and apparently it was much stronger than the pickup frame. Don't see why it couldn't be done.
RayP(MI)
01-01-2006 16:05:36
I have an electric/hydraulic pump on my truck to run the snowplow hydraulics. Even with dual batteries, (diesel) there are times that alternator is fighting a loosing battle keeping up with the pump. Last time I had alternator rebuilt, I had technician "biggie-size" it. Putting out up to 125 amps now, and has been able to keep up with needs. Many tractor systems wouldn't be able to keep up with the needs, as they are designed to run only a few lights, and keep battery up.
Gene Davis (Ga.)
12-31-2005 18:09:26
Fellow here put a convertible top setup on a Sears Lawn tractor and it did o.k, haven't seen it tried on anything larger yet. You would need a fairly large unit I suspect to be fast enough.
DickTN
12-31-2005 18:08:23
Surplus Center sells a couple of these units. Gonna be in the $350-$400 range depending on whether you want a unit for single-acting or double-acting cylinder. Looks like they are in the 1.3 GPM area at somewhere around 2000 PSI. Be forewarned that these are going to draw a LOT of current (One unit says 160 Amps @ 1500 PSI) You will need some real healthy cables in the 2/0 area to operate the pump and a darn good battery and charging system to keep up with the current draw. Good Luck with your project and Happy New Year!
Gene Davis (Ga.)
12-31-2005 17:56:04
