Tractor Talk Discussion Forum
2n
Greg Scroggs
01-09-2006 06:37:31
Will someone correct me about the 2n i bought. Isn't the 6 volt system a negative ground system?
Tom-Pa
01-09-2006 16:10:32
 Re: 2n in reply to Greg Scroggs, 01-09-2006 06:37:31
The only time that the 2N or any N for that matter requires a neg. ground is when it has been converted to 12 volt service. the Alternator requires neg. ground. Otherwise use the positive ground for the 6 volts.
old
01-09-2006 08:37:03
Well as the others have said it should be + ground.
Bob
01-09-2006 07:26:21
Originally, the "N""s were (+) ground, and if it still has the original square-can ignition coil, the spark at the plugs will will about 30% more effective with the battery ground polarity (+), than if it is mistakenly cannected with (-) ground polarity.
If the unit is running well, and the generator is charging well, you may wish to keep it as-is, if you do decide to change the ground polarity, be sure to polarize the generator AFTER the polarity change, but BEFORE starting the engine after the polariy change.
wfw
01-09-2006 06:54:28
2n tractors were positive ground from factory, may have been converted at some tome
