Tractor Talk Discussion Forum
Contenatal E-227 engine
old
01-10-2006 12:17:42
Is there any tractors that use this engine?? Just asking because I have one that did run good when the machine was parked last summer and I don't need the engine. I would prefer to find some one that could use it instead of it sitting and rusting away.
Thanks
keith zessin
01-10-2006 16:27:19
 Re: Contenatal E-227 engine in reply to old, 01-10-2006 12:17:42
Is this a 4-cylinder overhead valve or 6 cylinder flathead ?
old
01-10-2006 17:18:29
 Re: Contenatal E-227 engine in reply to keith zessin, 01-10-2006 16:27:19
6 cylinder flat head, with a mag instead of a distibutor
J. Schwiebert
01-10-2006 16:10:30
We can make this real simple. E model Continentals are 4 cylinder overhead valve engines. The numbers do not seam right. However if it a six cylinder L head engine it is an F-227 not an E model. The F-227 replaced the F-226. Some parts interchange some do not. Questions
old
01-10-2006 17:20:56
 Re: Contenatal E-227 engine in reply to J. Schwiebert, 01-10-2006 16:10:30
The E could in fact be an F sort of hard to read, it was cloudy out which also doesnt help tring to read numbers. But yes its a 6 cylinder flat head with a mag on it.
Glen in TX
01-10-2006 21:38:05
 Re: Contenatal E-227 engine in reply to old, 01-10-2006 17:20:56
Yep probably a F227 but I knew what you were talking about. The one I had used a Delco dist. on top side. It was pain to get to under hood of compressor too. Had them try to sell me F226 parts once but they wouldn't work at all. I didn't find any Cletracs using them and most all those used Hercules or Buda engines.
Doug in IL
01-10-2006 15:57:19
Old, I used to have a Cletrac crawler that had a Continental L head 6 cylinder in it. That number sounds familar.
J. Schwiebert
01-11-2006 10:37:32
 Re: Contenatal E-227 engine in reply to Doug in IL, 01-10-2006 15:57:19
Don't have any parts left out of that Cletrac?
Doug in IL
01-12-2006 05:37:40
 Re: Contenatal E-227 engine in reply to J. Schwiebert, 01-11-2006 10:37:32
No, I don't.
old
01-10-2006 17:22:15
This engine is a 6 cylinder flat head
Doug in IL
01-11-2006 05:36:05
 Re: Contenatal E-227 engine in reply to old, 01-10-2006 17:22:15
Now that I have read the later replies, I remember that the Cletrac engine was a F226 Continental. It was a flathead. L head and flathead are two different names for the same type of engine.
old
01-11-2006 07:47:32
 Re: Contenatal E-227 engine in reply to Doug in IL, 01-11-2006 05:36:05
yep I knew flathead and L head where the same just depends on who you talk to as far as what they call them. LOL
Glen in TX
01-10-2006 12:38:57
I've only seen the 227 in industrial equipment like compressors, welders, forklifts, road equipment and the like. It may have been used in some tractors? Oliver 70 used a Continental 201 but later Olivers had their own engine. I had a Joy air compressor with the 6 cyld. 227 gas flat head Continental but sold it last year. What machine is yours in? You might advertise to the industrial / construction equipment folks. Try some of these links I have for Continental parts.
www.montesequipment.com
www.budgetforklift.com/index.html
www.foleyengines.com
www.continentalengines.com/default.asp
www.industrialenginerebuilders.com/index.htm
J. Schwiebert
01-11-2006 05:34:04
 Re: Contenatal E-227 engine in reply to Glen in TX, 01-10-2006 12:38:57
The 227 is the replacement for the F-226. The 227 has a flange type thrust bearing of course the 336 does not. Cylinder heads, cranks and blocks will not interchange other parts will. Questions. It would replace the F-226 used in the AG-6 Cletrac. How many Cletracs have you seen with the Buda?
Glen in TX
01-11-2006 12:32:39
 Re: Contenatal E-227 engine in reply to J. Schwiebert, 01-11-2006 05:34:04
A blue book I have only listed Cletracs with Buda, Hercules, and Cletrac engines. Check out the list for more at Cletrac site.
J. Schwiebert
01-11-2006 05:36:01
Hit the wrong key and did not catch it in time> That should be 226 not 336. Anybody have any M, J or B Continenetal parts?
old
01-10-2006 13:10:29
Right now its sitting in a Galion road roller, I sold the front roller off it to a guy with his own run way for his plane. I'd just like to salvage all I can from it instead of selling it off for scrap. This engine was rebuilt now all that long ago as far as how many hours it has on the rebuild. It even has a tag on the engine telling what was done to it.
Glen in TX
01-10-2006 15:07:25
 Re: Contenatal E-227 engine in reply to old, 01-10-2006 13:10:29
I figured it was in something like that. Still see those old rollers around a lot with older engines in them on smaller construction sites. Ask Monte at Monte's Equipment at the link I gave you if he knows if it will fit in place of others in tractors. I bet someone has tried it and knows.
