Tractor Talk Discussion Forum
Perkins 236
Matt Bunsen
01-10-2006 19:13:38
I have a friend who is having head gasket problems with a Massey Ferguson 180 with the Perkins 236. Is this a wet or dry sleeve block, and what is the liner height above the deck.Thanks for the info.
J. Schwiebert
01-11-2006 10:35:16
 Re: Perkins 236 in reply to Matt Bunsen, 01-10-2006 19:13:38
It is a dry sleeve block. How does the head gasket fail? Also when the gasket is replaced do you do a retorque?
Matt Bunsen
01-11-2006 13:27:53
 Re: Perkins 236 in reply to J. Schwiebert, 01-11-2006 10:35:16
I haven't personally worked on the tractor. I think it is getting coolant into one of the cylinders because it smokes white and losses power after getting up to temp. He has had the gasket done 3 or 4 time already by the same so called mechanic. I told him to have him retorque it also. Torque all headbolts then loosen them up and retorque them to preflatten the gasket. I do alot of inframe overhauls of Detroit Series 60 and C12 Cats.
