Tractor Talk Discussion Forum
Biggest Agricultural or Construction Tractor ever
Brad Wright of
01-11-2006 13:25:58
What was the Biggest Agricultural or Construction Tractor ever made. I believe it was the Big Bud but I am not sure.
Big Bud
16V-747
Manufactured: 1978 - 1978 Total built: 1 Power: Drawbar (HP): 900 Engine: Manufacturer: Detroit Diesel Fuel: diesel - turbo Cylinders: 16 Displacement (ci): 1472 Compression: Rated RPMs: 2100 Torque (ft-lbs): Firing order: Oil capacity (qts): Transmission: Forward: 6 Reverse: 1 MFWD: standard (4WD) Capacity: Fuel (Gal): 1,000 Tires: Ag front: 35x38 Ag rear: 35x38 Dimensions: Weight (pounds): 95,000 Wheelbase (inches): Length (inches): Width (inches): Height (inches): Ground clearance (inches): Electrical: Battery volts: Ground: Battery cold-cranking amps: Alternator amps: Serial Numbers: 1978 7816 Comments: The Big Bud 16V-747 is the largest tractor made in the 20th Century. It was custom ordered by Rossi Farms of California. It is 14 feet tall, 20 feet wide, and 28 feet long. Fully loaded with fuel and ballast it weighs 130,000 pounds. The tractor is still in use in Montanta.
CLW
01-11-2006 19:58:43
 Re: Biggest Agricultural or Construction Tractor e in reply to Brad Wright of MO, 01-11-2006 13:25:58
Big Roy needs duals. That would be one mean dude.
Wayne in TX
01-11-2006 14:59:22
Depends on definition of "tractor" and "largest". I know some of the equipment I have seen on shows like Mega Machines have shown some pretty big pieces of equipment (like the LeTourneau 2350 which is a wheeled loader with 53 yd bucket and 600 hp motors on each wheel or the Cat 944d 1375 hp 412000 lbs). There are some pretty big tracked construction tractors that are used with rippers, pans and blades (Cat D11 over 200,000 lbs and the Komatsu 575A-2 with 1100 horsepower 300,000 lbs) that are bigger than the Bud.
Bob
01-11-2006 14:28:44
The Versatile Big Bud is nothing to sneeze at, either. I think it "has" the Big Bud, in physical size, but the Big Bud has more HP.
730 virgil
01-11-2006 19:21:56
 Re: Biggest Agricultural or Construction Tractor e in reply to Bob, 01-11-2006 14:28:44
was or has big roy been used for farming or road building ?
Bob
01-11-2006 20:05:44
 Re: Biggest Agricultural or Construction Tractor e in reply to 730 virgil, 01-11-2006 19:21:56
I think it was more or less a prototype, but I believe they did at least do field trials with it. I'll look up another link, and post it below.
Link
Janicholson
01-11-2006 13:38:06
On the net, bigbud.com
I've lived in Havre MT (where it was built), and know several of the factory employees who built it.
I've also been at the (still existant) factory when it came back from use in Florida. It is massive.
The tires are taller than my 6'1-1/2" hair by about 15 inches, ground to top of rubber.
JimN
