Tractor Talk Discussion Forum
961 Ford value
KS Farms
01-13-2006 19:27:52
I have a 961 Ford diesel that I need to sell, how much should I be asking? The motor needs to be overhauled (#2 has low compression)but the tin and trany are good. I have both front ends. Should I sell it as a unit or sell the wide front seperate?
john in la/md
01-14-2006 12:29:01
 Re: 961 Ford value in reply to KS Farms, 01-13-2006 19:27:52
If it is a 961 it has a 5 speed and live pto (double clutch)
While not as popular as a 861 they are still nice.
A 861 in perfect shape and paint will bring up to $5500 and I would guess a 961 to be about $5000
The problem is yours needs a engine rebuild and paint. Its worth $1000 as scrap but you may get some one to go $2000 with both front ends.
Most likely worth more in parts though.
ErnieDD
01-14-2006 09:04:40
Which transmission (5 or 10 speed, 2 step clutch) and does the engine have the counterbalance weights?
I have seen them $4500-5500 with a "good" engine and a paint job. $1500 less for 10 speed or select o speed. Power steer is a plus, but the little buggers steer easy as it is.
There is one on ebay now.
KS Farms
01-14-2006 12:36:13
 Re: 961 Ford value in reply to ErnieDD, 01-14-2006 09:04:40
It is the 5 speed, and it does have the counter balance weights in the engine.
Thanks for the reply.
Joe in MN
01-14-2006 06:14:19
If your wanting to sell it, do it any way you can, both ways if possible, If you don't know what there worth, ask your local implement dealer as to supply and demand price, there different in every area, good luck.....
