Tractor Talk Discussion Forum
Yahoo!!! Tank is clean
Keith-OR
01-15-2006 18:22:56
Fuel tank is clean, no more weeds inside or crud.
Test results of sulphric acid on galvanized tank,no notable change in galvanize, just removed paint after 2 1/2 hrs.
Will post pic. tomorrow of test area that was exposed to the sulphric acid.
Used sulphric acid to dissolve the weeds, it also cleaned all the crud out of the bottom of tank. Looked inside with flashlite sure looks clean, just a few spots here and there. Nothing that a couple handfulls of nuts and bolts and shaking won't take care of.
Keith & Shawn
doogdoog
01-15-2006 18:56:15
 Re: Yahoo!!! Tank is clean in reply to Keith-OR, 01-15-2006 18:22:56
Aloha Keith, Did you use the sulfuric acid straight from the container or did you cut it down with water? TIA
Mahalo,
doogdoog
Keith-OR
01-15-2006 19:02:21
 Re: Yahoo!!! Tank is clean in reply to doogdoog, 01-15-2006 18:56:15
Straight from the container !!!!
Keith & Shawn
