Tractor Talk Discussion Forum
hat field fertilizer question
Rich Iowa
01-16-2006 04:21:28
It has been in the 40s during the days here and no precipitation for a while. I was thinking about getting the fertilizer on my hay field while I could, and try to save a couple bucks. Could I spread the fert. on with the ground being frozen at night with out it running off. I needed 180lb of Phosphorus per acre on about 5 acres. I was going to spread half last fall and the other half this spring, but the weather turned cold and snowy before I could get it applied. Should I spread it all now, or wait and spread half after my 1st cutting? Thanks for any help
John (C-IL)
01-16-2006 05:28:50
 Re: hat field fertilizer question in reply to Rich Iowa, 01-16-2006 04:21:28
If your ground has a lot of slope, don't spread the fertilizer on frozen ground. Looks like you need about 400# of TSP, you should definately make that in 2 applications. Probably the first as soon as possible and the second this fall after the last cutting.
