Tractor Talk Discussion Forum
block heater
Arvil Hill
01-16-2006 05:12:57
I am considering putting a block heater on my kubota L245DT so it will start better in cold weather. I have found more than one type. I need advice on which one will work best on this tractor. Your help is appreciated. ahill@grnco.net
buickanddeere
01-16-2006 13:55:12
 Re: block heater in reply to Arvil Hill, 01-16-2006 05:12:57
Excellent idea. Even if the engine will start without using a block heater. The reduction of engine wear, reduction of fuel burned and reduced electrical system stress more than pays for the heater.
gumby
01-16-2006 12:36:50
I'd vote for the in-block style, but you might be limited by the amount of underhood space or simply the location of a block plug to access. The next best would be the type that goes in the radiator hose. I've used one like that in my old Volvo for about 15 years with no problems. You've got to leave it plugged in all night, but it does a reasonable job of getting the block warm.
I've got a L3010 Kubota (about 6 years old) that starts right up even when the temp is down around 0 degrees F. Wow, I couldn't believe it when I hit the starter switch. The newer diesel engine designs seem to be much easier to start at all temps.
Good luck.
R. John Johnson
01-16-2006 12:15:27
Arvill
The in block heaters are better than the external tank type. No fancy plumbing, no need to be careful on location to get circulation, no tank to secure to the block somehow. Since there is no heat loss through a tank or hoses you need less wattage to heat your block. Sometimes you will find that you might have a choice of different wattage heaters, and if you do always get the one with the higher rating.
My two cents
John
DJM75
01-16-2006 09:34:40
The in block type are the best and like caseyc said get an original then it will fit.
JMS/MN
01-16-2006 08:50:08
My Gehl skidloader has a 46 hp Kubota engine- has a factory heater in the rear of the block- opposite end of the fan. Is yours drilled and plugged there?.
caseyc
01-16-2006 06:30:04
just get one from the dealer so you know it"s right.
casey in SD
