Tractor Talk Discussion Forum
ford tractor
benny sepulvado
01-17-2006 07:51:35
i have a ford 3000 tractor that i change
the fuel filter head and i cant stop the fuel lines from leaking diesel. can someone help me?
Ken L.
01-17-2006 16:02:21
 Re: ford tractor in reply to benny sepulvado, 01-17-2006 07:51:35
Some of the lines have rubber grommets for seals. After a while the rubber goes bad and they leak. Take a line off and check. If they use rubber seals, just get new ones. If these are injector lines, this will not apply.
CharlieN
01-17-2006 15:40:32
turn the valve off under the tank.
mno
01-17-2006 12:35:01
I"m not sure,I would look at the to heads where the lines seals make sure they are the same,check the lines ends see if any damage,if more then one leaks and they did not before sounds like head.
