Tractor Talk Discussion Forum
farmal cub
farmtractor1941
03-20-2006 17:54:03
over heats easy. pushes out over flow.
old
03-20-2006 18:08:12
 Re: farmal cub in reply to farmtractor1941 , 03-20-2006 17:54:03
Either you are filling it to full or the cooling system is clogged up. I would flush the colling sytem. Drain it, fill with vinagar, run it till good and warm. Let if cool then flush it out with a garden hose, if you can hook the hose to the block drain plug your better off. Let it flush with the hose for about and hour or more then refill with anti freeze
Gene Davis (Ga.)
03-20-2006 18:55:20
 Re: farmal cub in reply to old, 03-20-2006 18:08:12
If this tractor does not have a water pump be sure you mix the anti-rfreeze and water BEFORE pouring it into the radiator to avoid running hot because a big slug of antifreeze won't rise and mix with the water in a thermo-syphon cooling system like water would,because it is too heavy.
