Tractor Talk Discussion Forum
Propane fuel line suggestions
Engineer20
03-20-2006 18:23:20
Anyone know what other material I could use instead of copper for propane fuel lines on my tractor?
Thanks for all your help!
aslack99
03-21-2006 15:08:44
 Re: Propane fuel line suggestions in reply to Engineer20, 03-20-2006 18:23:20
Yes it should 5/16" steel braided motor fuel hose for lp.
Maark
03-21-2006 10:10:54
So why do we use copper to go from our 1000 gallon LP tank to the house?
KEB
03-21-2006 10:13:05
 Re: Propane fuel line suggestions in reply to Maark, 03-21-2006 10:10:54
Because your 1000 gal propane tank doesn't vibrate and work harden the copper, causing it to crack.
Keith
Glen in TX
03-20-2006 20:37:26
Don't use copper line or makeshift hoses. Check with your local propane dealer and they should have fittings and LPG hose to make them up or can order them for you.
Dave Sherburne
03-21-2006 08:58:26
 Re: Propane fuel line suggestions in reply to Glen in TX, 03-20-2006 20:37:26
Glenn has it right You must use a special hose for
LP gas and special pipe joint compound for threaded
fittings. LP will seep right through regular fuel lines
Chris(WA)
03-20-2006 20:19:50
Fuel rated hose can be used but only with the correct fittings and crimp attachment. Has to be correctly pressure rated too.
IaGary
03-20-2006 20:14:00
Black pipe is the only other thing I've seen used.
