Tractor Talk Discussion Forum
carbureator TO-35
sooners
03-20-2006 19:44:42
My TO-35 Massey has a carter carb that I cant figure out the model #. It has a O-985 on the bottom bowl area and a O-834 on the top area that the float is attached to. It says carter ut on the side. The manual states that it was manufactured with three different carter ut models ut-2223s, ut-2418s, ut-2612s. Any ideas?
Jerry/MT
03-20-2006 20:58:32
 Re: carbureator TO-35 in reply to sooners, 03-20-2006 19:44:42
Ask this on the Ferguson Forum and somebody will be able to help you. The Carter's were ID'd with a brass tag that invariably broke off and it's hard to know what the correct model is. If you have a manual for the tractor it may tell you. I have one that came off a TO-30 and I can't figure out the true Carter model number because it has no tag. It'sefinetly a UT, probably of the 22XX series but beyond that I haven't found anybody to give me any diffinitive model number. There is a carb shop that I contacted that will ID it but it is very expensive as they dismantle the carb and measure the parts and check them against the specs. Good Luck.
