Tractor Talk Discussion Forum
Dumb Luck - Happy Ending
Christos
03-20-2006 20:52:21
Well, the tractor is fine and now back at the farm the valve cover gasket did fail (manufacture's defect) but the reason it wouldn't turn over was because of something I had been suspicious about - the gas tank - instead of rust like I had previously thought, it was the gas 'varnish' that had clogged up the fuel line as it had flaked off the interior of the gas tank. Sea Foam should fix that problem.
Anyways, I couldn't have asked for better tractor doctors than the mechanics I've met and let work on my baby.
Time to get to work on getting a plow for said tractor so I can plant my sweet corn in a few weeks after all the snow has melted away here in good ole Sno-hio!
Christos
TRC
03-21-2006 05:28:34
 Re: Dumb Luck - Happy Ending in reply to Christos, 03-20-2006 20:52:21
That's great news. Go get that plow! Tim
Mike M
03-21-2006 05:24:53
If you keep having trouble with that tank maybe a taller standpipe in the fuel bowl will help ?
Harley
03-20-2006 21:16:27
Hey glad it wasn't anything worse. Ya them things happen, and usually just when you are so proud of yourself for fixing something. Harley
