Tractor Talk Discussion Forum
vac case tractor
Jennifer Clarke
03-22-2006 19:49:12
i have my case tractors serial number. i would like to know what year it is and the estimated value of my tractor. is there a web site were i can find this information.
thank you,
Jennifer
Jennifer Clarke
03-23-2006 12:54:04
 Re: vac case tractor in reply to Jennifer Clarke, 03-22-2006 19:49:12
i would like to thank all of you for helping me if i have any more questions i will be sure to ask yall.
thank you so much
Jennifer
JR(CASE38MAN)
03-23-2006 06:50:31
third party image
Since it is a 7-diget serial number..you take the first 2 numbers which are 48 and subtract 4 making it a 44 model..where are you at an maybe I can give you a ball park figure of the value...JR
old
03-22-2006 20:37:28
Look on this site on the left under research& info. Click on serial numbers and then case then the type you have and you should be able find out from that
TomTX
03-22-2006 19:53:46
Jennifer,
Post back here and give me the serial number, and maybe I can help you.
Tom
Jennifer Clarke
03-22-2006 19:59:40
 Re: vac case tractor in reply to TomTX, 03-22-2006 19:53:46
Tom,
the serial number is vac 4827811
Jennifer
earlschieb
03-22-2006 21:06:52
 Re: vac case tractor in reply to Jennifer Clarke, 03-22-2006 19:59:40
This site says that it is a 1944 model. As far as worth, you would need to post a picture, and tell us about how it runs, mechanical problems, and how it drives. Most Vac tractors around here are not worth much more that $1000.00, or even less.
Case Model B, C, CC, CI, CO, R, RC, D, DC, DI, DO, LA, LAI, S, SC, SI, SO, V, VC, VI, VO, VAC, VAH, VAI, VAO, and W
[ Return to Models] [ Return to Main List]
Year Starting Serial Number 1929 300201 1930 300301 1931 300401 1932 300501 1933 300601 1934 300701 1935 300801 1936 300901 1937 301001 1938 4200001 1939 4300001 1940 4400001 1941 4500001 1942 4600001 1943 4700001 1944 4800001 1945 4900001 1946 5000001 1947 5100001 1948 5200001 1949 5300001 1950 5400001 1951 5500001 1952 5600001 1953 5700001 1954 5800001 1955 5900001 1956 6000001 The Serial Number is located stamped on a name plate fastened to the instrument panel for most Case tractors. Can also be on toolbox
Les
03-23-2006 04:05:36
 Re: vac case tractor in reply to earlschieb, 03-22-2006 21:06:52
You can't put a dollar value on the sentimental attachment to a VAC, earlschieb.
