Tractor Talk Discussion Forum
JOHN DEERE 2510 PROBLEMS
jimwen
03-23-2006 18:52:06
I need some advice on 2 problems I am having with a 1966 JD 2510 gas tractor narrow front. Tractor fires right up and runs very good, looks good as well. The clutch when released the tractor seem to hop excessivly or jump untill you throttle up and start moving. I have not pulled anything to see if the clutch is slipping since I just bought it Monday. 2nd problem it that the 3 point seem to take a long time to raise and is kinda jumpy. Oil is full, power steering works great. Any help to determine the problems would be a great help.
Thanks Jim
johndeerejon
03-23-2006 19:02:17
 Re: JOHN DEERE 2510 PROBLEMS in reply to jimwen, 03-23-2006 18:52:06
I would try changing all the filters and fluids first on this thing if it were me. Do you know the history of this thing? That could have alot to do with how it has been treated during it's life. As for the clutch, I would try to pull a load and if it slips and jumps while at higher RPM's. You may have to clutch it.
