Tractor Talk Discussion Forum
? about a 4010 and planter
hogman_2002
03-23-2006 19:21:57
Will a 4010 be able to pull or even lift a 7100 8 row 30" planter?
1206SWMO
03-23-2006 22:58:27
 Re: ? about a 4010 and planter in reply to hogman_2002, 03-23-2006 19:21:57
A neighbor used to pull a 12 row 7000 JD planter with a 4030 JD that had single rear tires and no cab.
Another neighbor pulled a 16 row 7000 planter with a 4320 JD.
95EB
03-23-2006 20:20:53
Yes, it will, thought it might involve cranking up the hydraulic system pressure, and if you have enough front end weights, that will help as well. If you're just running seed boxes and not herbicide or insecticide boxes, that will help a bunch. Power won't be a problem.
billyiron
03-23-2006 19:55:33
youll need lift assist,,after awhile youll knock out the load shaft seals,,we pulled a 8-30 7000 ok,,mostly in 4th gear,,with liquid fert,, I think you need something with bigger 3-pt,,,my 2-cents,,,,billy
Dean Barker
03-23-2006 19:28:29
It should pull it easily if it is a bare planter.
I plan on pulling a White 5100 12-30 bare planter with my 1655 Oliver which is about the same horsepower. Your hydraulics should be a lot better than my Oliver in lifting a planter.
