Tractor Talk Discussion Forum
Ford 5000 Loader Hydralics
Todd 20
03-24-2006 04:07:36
Hello,Can anyone tell me how else I may hook up the hydralics for a loader on a Ford 5000. Right now the preasure line is being feed with one of the remote outlets that is under the seat and the return line is plumed up to the oil level plug at the lower left side of the transaxel. The only problem with this hook up is I have to hold the control lever open that is under the seat to feed the line. And I can't opperate the 3-point at the same time as the front loader.
Thanks in advance
Todd
souNdguy
03-24-2006 08:46:43
 Re: Ford 5000 Loader Hydralics in reply to Todd 20, 03-24-2006 04:07:36
As long as you are using an OC spool that is being fed from the OEm remote.. then how about a bunji to hold the remote open? As for using the 3pt and the remote.. there is a section ont he owners manual about this.. however a heavier load ont he loader than ont he 3pt will make the 3pt raise up.. etc... might still work for you if you need to tote a heavy dox scraper or mower ont he 3pt.. etc..
Soundguy
Todd 20
03-24-2006 09:44:33
 Re: Ford 5000 Loader Hydralics in reply to souNdguy, 03-24-2006 08:46:43
Thanks for the information, In your reply you mention a OC spool, is that the spool(valve) that has a lever about 7" long under the seat? When I push it forward it preasurizes the other remote line ( There is 2 on the tractor) I do have a small chain hoding the valve open when I wan't to opperate the loader, I am just wanting to opperate the loader and a 3-point blade at the same time for some landscaping. I have some pictures but I'm not sure how to attach them in this form?
Thanks Todd
souNdguy
03-24-2006 09:50:34
 Re: Ford 5000 Loader Hydralics in reply to Todd 20, 03-24-2006 09:44:33
No... As my post stated.. make sure your loader spool is OC, and then tie open the OEM valve ont he remote.. etc.
As for dual use.. there is a section in the owners manual for using the remotes and 3pt lift at the same time.
Soundguy
