Tractor Talk Discussion Forum
Farmall H
Bower
03-24-2006 07:16:32
does any one know if you can turn up the hydraulic pump on a Farmall H? I realize this is not a very big tractor but it should still be able to lift a hay mower. Thanks for all inquires.
dej(JED)
03-24-2006 10:31:31
 Re: Farmall H in reply to Bower, 03-24-2006 07:16:32
Change the oil out. When it breaks down it won't lift well at all. It should lift a mower with no problem whatsoever. If the oil is good then the gear pump is bad. They go for about $50 used.
Wayne Swenson
03-24-2006 08:17:31
There was an update kit to increase pressure many years ago; if the pump gears are not worn and the clearances reduced on the pump so the gears have minimum clearance the pressure can get up to 900 PSI or thereabouts.
Nebraska Cowman
03-24-2006 07:34:00
An H does not put out a lot of pressure. You might try a larger diameter cylinder.
