Tractor Talk Discussion Forum
pointers...
rboulware
03-27-2006 13:28:22
Can you all give me GOOD pointers for looking at a 4020 tractor to buy? Any thing to look for as far as the engine is concerned?
any help is appreiciated..
Thanks
730virgil
03-27-2006 14:34:46
 Re: pointers... in reply to rboulware, 03-27-2006 13:28:22
personal preference would be dual hydraulics , if someday you want to hang loader on it , wide front , power shift good if you plan to use tractor for pto work . get a fiend to go with you when you find one that sounds good to you
rboulware
03-27-2006 20:30:09
 Re: pointers... in reply to 730virgil, 03-27-2006 14:34:46
Ohh yeah, I will have Dual Hydrolics FOR SURE!!! Diff locking as well...
Wide front
Rops
And I would Like to have a loader as well...
rboulware
03-27-2006 13:57:26
Yeah but What is the BEST way to evaluate like the engine just by listening or observing the smoke it pruduces....OR how would I evaluate the tranny or the clutch?
Jon Hagen
03-27-2006 16:56:37
 Re: pointers... in reply to rboulware, 03-27-2006 13:57:26
You need to take along someone who is very familiar with running,or better yet repairing the 4020 tractor. That person will know where to look for the many possible problems.
rboulware
03-27-2006 17:51:27
 Re: pointers... in reply to Jon Hagen, 03-27-2006 16:56:37
You are SO right....I need to find a good Mecanic to go with me..... .
In general if the tractor is good..... lets say EVERYTHING checks out good. Does this mean there should be little chance of catostrophic failure? Has any one seen a 404 engine with a thrown rod?
Jon Hagen
03-27-2006 18:30:31
 Re: pointers... in reply to rboulware, 03-27-2006 17:51:27
If everything checks out,you have every chance of several thousand more trouble free hours.
Many of the 404 engines went well over 10,000 hrs before needing an overhaul. The bottom end of the 404 is pretty rugged,so not much rod problems.I have been told,never reuse the rod bolts if you remove the rod caps,always replace with new bolts.
Jon Hagen
03-27-2006 13:52:52
They were all pretty good old tractors,but IMHO the 69-72 with 12V electrics,side console hydraulics and improved pto mechanisim,along with many other small improvements,are the best 4020's.
