Tractor Talk Discussion Forum
Trailer towing limits??
TSW
03-29-2006 18:53:28
This is probably going to get complicated but here goes. I’m toying with the idea of hauling a piece of equipment from NJ through PA and into NY. The item weighs 14000lbs. I have a 9-ton trailer, which is registered in NY for 18000 Lbs. The trailer weighs 4000lbs empty is tri axle and has good brakes on all wheels. I have either a ¾ ton Dodge diesel pickup register at 8800 lbs or a 1 ton Dodge diesel dually register at 18000 lbs. to pull it. The ¾ ton has a class 5 hitch. The 1-ton only a class 3 hitch. Both are standard transmissions. The ¾ ton has been tweaked and has more power.
I have hauled 12000 lbs with the ¾ ton and trailer combo for short distances before and been comfortable with it. I have a normal class D NYS license, which as I understand allows me to drive a single vehicle not exceeding 26000 lbs or a truck trailer combo not exceeding 26000 lbs.
I know most of you will recommend not trying this at all and to be honest I probably will NOT do it, but for curiosity sake if nothing else, what kind of legal trouble can I get into?
john in la
03-31-2006 19:53:15
 Re: Trailer towing limits?? in reply to TSW, 03-29-2006 18:53:28
I think Bret spelled it out for you but let me put it into other words that may explain it better.
There are two types of trucks on the road and each have their own laws.
One is a commercial hauler.
Under this blanket their are Private carriers (haul only their own stuff)
and For Hire Carriers (haul for hire; other peoples stuff)
If this hauler weighs over 10,000 lbs or better yet is licensed to weigh over 10,000 lbs; OR hauls hazmat in quantities large enough to require placards; he falls under DOT rules. These rules state he MUST register with DOT; display name and DOT # on the door. If this hauler carries other peoples property (for hire carrier) he must also display a ICC #.
Their are other requirements of insurance amounts; IFTA (fuel tax) reporting; log books.
This is all spelled out in Part 390. (see link below)
Second is the one time hauler of personal property. 390.3 f3 (see link below) gives you the right to weigh over 10,000 lbs (if you do NOT haul hazmat) and not follow these rules. BUT you better not make any money and be ready to prove it. Hauling a tractor to your summer house to do yard work would fall under this rule. Hauling your tractor to your summer house to clear a spot to plant trees that later will be sold does NOT. You made money off the trees.
Different subject from above and should not be confused with any thing said above.
CDL
If you weigh over 26,000 lbs gross OR haul hazmat you need a CDL. If your trailer is licensed for more than 10,000 lbs you need a Class A CDL. YES if you are licensed for under 26,000 lbs you can pull a 10,000 lb trailer without a CDL but then we get into weight laws.
You are only allowed so much per axle depending on what size axle/tires it has.
Where it gets tricky is you need a truck capable of pulling and STOPPING a 10,000 trailer. To get this you (I think) need to get into larger trucks. One way I have seen them get around it is by getting a truck rated over 26,000 lbs but putting a 25,000 lb license on it. To avoid daily hassle they mark on the door..... .
GV weight 25,000 lbs
Scale the load
A truck comes with 2 weight ratings...
GVWR gross vehicle weight rating
GCWR gross combined weight rating
You can license a Toyota pickup for 80,000 lbs but that does not mean you can weigh that much. You must never exceed your GVWR or GCWR. For small trucks they will check it. Rip the tag off the door; does not matter they have a book listing ratings.
Even when all this is correct you still need to place the load on the trailer properly so you are not over axle weights.
Now I will say it again.
Glad you found someone to haul your load BUT..... ..... ..
How can you pull a 14,000 lb load and be under 26,000 lbs.
Your 1 ton (I think) is to small to do the job.
So we need a larger truck. Say a 2 ton.
Your 4000 lb trailer will have all it can handle with 14,000 lbs. If we can get the load placed just right we may be able to scale the load.
If so we may squeeze in under 26,000 but it is going to be close.
Bret4207
04-01-2006 06:50:54
 Re: Trailer towing limits?? in reply to john in la, 03-31-2006 19:53:15
John- I believe the ICC# has pretty much been superceded by the DOT#. We don't even look for an IC# anymore.
I agree with most of what you wrote but the big point for these guys to remember is ARE YOU A COMMERCIAL VEHICLE? Uncle Petes RV may have a GVWR of 40,000 lbs but until he starts hauling fruit back from Florida he isn't a CMV and thats all their is to it.
Now Farmer Joe, (like me), he has a 1/2 pick up with a GVWR of say, 6600 lbs, and a dual axle trailer with a GVWR of 5,000 lbs. The Combined GVWR is in excess of 10,000 lbs and he makes $$ off the farm (not much, yeah I know the story). He IS commercial.
Joe the landscaper has a 3/4 ton truck and a flatbed, GVWR of 8800 and 11,000. He's commercial, he needs a regular license.
Jim the landscaper has a truck with a GVWR of 12,000 and a 20,000 lbs trailer. He needs a class A because the CGVWR exceeds 26,000 lbs and the trailer exceeds 10,000 lbs. He can have them registered for 5 and 8,000 lbs respectivly but it's the CGVWR we go by.
I'll throw a wrench in the gears to illustrate where some guys get in trouble- Fred the foundation guy has a 3/4 ton truck, GVWR 8800 lbs. He's not a CMV. Lets say the truck weighs in at 5,000 lbs bare. Fred's got one of theose neat little dump boxes on the truck. He goes to the pit and gets a nice big load of stone. Ooops, here's Tpr Martin driving down the road fat, dumb and happy. I pull Fred over and notice the weigh slip from the quarry says he grossed at 11,980 lbs. I scale him and he weighs 11,950 on my scales. He is now a CMV becasue his actual weight is over 10,000 lbs. He's also going to be over registered weight, probably over his tire weight rating, maybe breaking some springs, duals touching at the innner sidewall, no fire extinguisher, triangles or flares, etc, etc, etc. Am I out to ruin Freds day? Nope. Do you want Fred following your teenage daughter down the road in her Neon and coming to a stop sign? I doubt it. Should Ol'Fred have put just a little more thougth into this? You tell me. Is Fred gonna swear up and down I had it in for him? You betcha! Welcome to my world.
TSW
04-01-2006 11:13:42
 Re: Trailer towing limits?? in reply to Bret4207, 04-01-2006 06:50:54
Id sure rather have Fred than some idiot with a cell phone in their ear following her! Of coures if Fred has the cell phone its a different story. HA!
TSW
04-01-2006 06:25:38
Ok I got a slightly better grasp on it now. As I see it I would not fall into the “Commercial” Category. The equipment is my own and I don’t make any money off it in any way. They are just basically toys that cost me money! So let’s forget my situation all together.
Let’s concentrate on, let’s say a landscape contractor. He is certainly doing it for profit. They often tow trailers over 10000 lbs. and of the dozen or so I talked to in the last couple days none have anything but a regular license. All but one had no idea what the GCWR of their truck was. If I understand what you’re saying now these guys are all “commercial” hailers and are technically illegal?!?
Apparently no one cares since only one had been pulled over for being over weight when he had a huge load on his trailer. The officer only asked for his driver’s license and registrations of both truck & trailer. Trailer was “registered” heavy enough and nothing was even mentioned about the truck and he let him go. Again no mention of truck GCWR!
What really baffles me is the GCWR of the pickup trucks. How would an officer or the DOT or anyone else ever know what your truck is “rated” at? Its not listed on the plate on the truck, just the GVWR is as far as I can see. Apparently your saying the registered weight is meaningless even though it appears that this is commonly what is used as a determining factor. My observation is the GCWR of the truck varies greatly depending on engine, transmission, wheels, tires and who knows what else. How on earth is this determined on the side of the road???? Is there someplace this is written that I’m not seeing?
It all boils down to the same conclusion. You might just as well do whatever you want since no one really knows (or cares) anyway. I’m sure if you ran into the right guy he could fine you for something no matter what the situation so just do whatever you feel is best in your own mind.
Bret4207
04-01-2006 15:13:31
 Re: Trailer towing limits?? in reply to TSW, 04-01-2006 06:25:38
We have a neat tool called "VINassist" that can do most trucks by vin number. It lets us know what the design parameters for that truck were. If that doesn't work, say on an older truck, we can go to the paper manuals if they're available, or find a dealer and get the info.
As for "knowing what your truck is rated at", that IS the GVWR. It's that simple. For instance- my Toyota says GVWR 5500 lbs. Thats it. Period. Now, does every cop you run into know that? No, like I said in an earlier post, it's a specialized field just like terroism, forgery, evidence collection. I was a road Trooper for 16 years before I moved over into the CVEU and had to basically start over in my way of thinking. Nothing like a new position to make you realize how smart you aren't.
As for the do what you want idea- your call.Trust me, we do "care" about it. You can scoff at the idea of safety, which is what this is about or not. I'd rather educate a guy than hand him a fist full of tickets.
Bret4207
03-31-2006 16:20:36
I forgot- You find the GVWR or "rating" of a vehicle on the VIN tag or the manufatuers spec plate, usualy on the door frame of a truck. A 3/4 ton truck rarely has a GVWR over maybe 8800 lbs. A 1 ton up to maybe 14,000 but 12,000 is more like it. If you have a super heavy duty rig it may be a little higher. F-450's are popular in Northern NY and I see some up to 17,999. Some guys have the rigs re-springed and the frame beefed and the tag will reflect that if it's done by a "good" company.
Theres a lot to this to do it right and state to state laws add to the muddle. The Federal Law doesn't help much if the State law is more restrictive. From the cops/DOT Inspectors point of view I wish it was simpiler just like all you guys do. At least most of you don't have tha added hassle of trying to deal with Canadian rules too!
TSW
03-31-2006 17:05:40
 Re: Trailer towing limits?? in reply to Bret4207, 03-31-2006 16:20:36
I’m really trying here but guess I just don’t get it yet. What I’ve discovered so far is its so confusing that no one on earth could possibly understand the laws including those that wrote them. This is one of many problems in this country but that’s another story.
As I said below, I hired the hob done so this is now all just for “clarity” of the law.
I went out and looked at the doors on the truck, through the owner’s manuals, and again at the registrations. Here’s what confuses me.
The door on my truck does indeed say GVWR 8800 lbs. What exactly does this mean? Can I not legally have a truck /trailer combo over 8800lbs no mater what its registered for. The police I talked to said they would just look at the registration and if that was enough. “You’re good as gold”
In the owners manual I finally found a small paragraph that listed my ¾ ton truck as equipped at GCWR 18000 lbs. So does this mean I can have a truck/trailer combo up to 18000lbs even though the door sticker says GVWR 8800lbs. Again then what is the registered weight for????? Why is there no GCWR even shown on the door?? Wouldn’t this be the more critical figure??
I also found an old registration from the previous owner of the 1-ton truck. The registered weight was indeed 26000lbs. I couldn’t find any GCVR in any of the manuals with that truck. I also found an old trailer registration in it for a trailer registered for 23000lbs. I have no idea what kind of license that owner had but thought it was interesting.
Thanks for all the info.
CNKS
03-31-2006 18:08:56
 Re: Trailer towing limits?? in reply to TSW, 03-31-2006 17:05:40
The 8800 on the door tag means the combined weight of the truck and it's contents cannot exceed 8800 lbs. That INCLUDES the tongue weight of the trailer attached to the truck, in other words the weight added to the truck by the trailer, that is the weight it carries, not the weight it pulls. The 18000 lbs is the maximum weight of the truck plus the trailer, the weight of both the truck and trailer when both are on the scale. For safety of both the truck and trailer, you do not want to exceed the weight limitations of either one. Using a scale: With the truck ON the scale and the attached trailer OFF the scale, the weight should be no more than 8800 lbs. The weight of the trailer and load alone, not attached to the truck cannot exceed the GVW of the trailer.
TSW
03-31-2006 18:39:49
 Re: Trailer towing limits?? in reply to CNKS, 03-31-2006 18:08:56
OK
This at least makes sense to me. I wonder why it is though, that the two police officers I questioned about this seemed only concerned with the weight on the registration. They never even mentioned weight “Ratings” at all.
CNKS
04-01-2006 13:13:25
 Re: Trailer towing limits?? in reply to TSW, 03-31-2006 18:39:49
Because they don't have the ratings of every vehicle on the road, at least not easily accessible. However, if you have a wreck the insurance company or other people involved are going to check into that, and if you are overloaded, or it can be proven that there is some defect you should have known about you can be sued. That's why you need to know the trailer and truck GVW's plus have the correct registration.
Bret4207
04-01-2006 06:27:04
Because the 2 guys you talked to aren't CVEU Inspectors. It's a specialized field and requires a lot of training, which goes on forever and ever. Trust me, I'm enroute to Albany for a week of training Monday. Thats why I recommend you talk to a truck guy from the Troopers or one of the DOT Inspecters that NYS DOT employs ( the guys in the orange jump suits).
Just to be clear- registered weight means nothing in the eyes of the FMCSA, licensing or anything else. The ladies at NYS DMV will let you register a VW Beetle for 26,000 lbs if you want or a KW for 5,000 lb even though the bare wt is way more than that.
TSW
04-01-2006 10:58:06
 Re: Trailer towing limits?? in reply to Bret4207, 04-01-2006 06:27:04
EXACTLY my point! Don’t get me wrong. I don’t doubt these laws exist. But if it takes someone in a specialized field with lots of training to comprehend these laws where the average cop on the beat can’t. What in hell chance does the average working stiff who’s trying to remain law abiding and make an honest living have????? ????? ? In my opinion NONE! It’s just a foolish waste of time and energy and worry.
Bret4207
04-02-2006 09:26:24
 Re: Trailer towing limits?? in reply to TSW, 04-01-2006 10:58:06
You've got a funny way of saying, "Thanks for taking the time and effort to try and explain this subject."
Bret4207
03-31-2006 16:08:37
NYS law requires you look at the GVWR of the truck and trailer, NOT THE REGISTERED WEIGHT. The nice lady at DMV will let you register that rig for what ever you ask her to, doesn't mean squat. Your class D is good on a single unit to 26,000lb, disregarding Haz Mat, for hire passenger type situations. Now- If you have a CGVWR ( Combined Gross Vehicle Weight Rating) over 26,000 lbs and the trailer is over 10,000 lb you need a class A by NYS law. This is State law, not Federal Law. Also, if you are doing this for hire or in relation to a business ( farms count) you'll need to get a USDOT number and display the carrier name and USDOT on both doors during the period your GVWR or CGVWR exceeds 10,000 lbs and while you're acting as a commercial unit. Again, this is a State law going into effect as of 07/05/06. If, this is the big if, you are doing this as a commercial venture or related to a business then once you cross a state line you'll need the USDOT anyway. Also if your GVWR or CGVWR exceeds 10,000 but not more than 26,000lbs and you're commercial you'll have to run a log book once you travel more than 150 air miles as the crow flies from your departure point. If youe xceed 26,000 lbs it 100 air miles, straight line. There are also farm exemptions if you are within 150 miles. It gets complicated.
Your best bet is to call your local NY State Police Barracks and ask to talk to one of the members of the Commercial Vehicle Unit. Explain what you want to do, why you are doing it and all the particulars. Then the Trooper can fill you in on what you'll need to have and do. We do this all the time and really would rather have someone ask us ahead of time and get it right than find you on the road and have another nightmare situation for both of us.
For the guys who tell you to wing it- They'll meet me sooner or later and it's not me paying the fines.
TSW
03-31-2006 18:28:19
 Re: Trailer towing limits?? in reply to Bret4207, 03-31-2006 16:08:37
Forget the situation above for a minute and lets concentrate on a common everyday occurrence.
At work we rent equipment, many of which weigh in the 8000-10000lbs. range. We commonly haul it on what is referred to as a 6-ton trailer. Our truck is the 1-ton registered at 18000lbs and the trailer we commonly use is registered at 14000 lbs. The trailer weighs about 2500lbs empty. Many customers, both homeowners and contractors also haul similar equipment, both theirs and ours. I don’t know what any of there own vehicles are rated or registered at for sure, but know very few if any have CDL & have never noticed any DOT #s on any of them.
Does or will any of this nonsense (for lack of a better word) apply to them or us? If so and anyone out there is aware of it, they could have a field day handing out fines. Easily 50 or more a day in our town alone.
I just can’t understand any sense to this at all! How could any normal working man or woman possibly be e
Ohio Mike
03-30-2006 17:39:59
I think the best thing you can do is go to your local higway patrol DOT and ask them. Make sure you talk to one who deals with this on a daily basis. Make note of name, time, date, ect. of when you went to local DOT. Then if you comply with what they tell you and if you get pulled over the one who stopped you will be a lot more understanding when they see your doing your best to be safe and legal. I've driven and been around trucks, and equipment for almost 40 years and I can tell you this for sure. Laws and regulations change daily and NOBODY knows them all! Go the extra step and it will pay off. Just some friendly advice, good luck.
john in la
03-30-2006 16:48:12
You can read what you want into a law because it is you that will pay the fine.
Who cares what NYS says. You are crossing state lines so that is federal.
383.91 Any trailer over 10,000lbs needs a class A CDL. So now you need a physical.
If you meet one of the exemptions you can get around this. (farmer; RV)
390.5 Any vehicle over 10,000 GVWR is considered a Commercial motor vehicle.
If you can meet one of the NEW exemptions; most times 390.3 f3 you can get around this. But you better be able to prove no compensation was made.
If you are considered commercial that opens a whole new can of worms.
TSW
03-31-2006 05:58:15
 Re: Trailer towing limits?? in reply to john in la, 03-30-2006 16:48:12
John
I can’t see were you are drawing the conclusion that any trailer over 10000lbs requires a CDL. I (along with a couple others at work) read the link you provided several times and can’t see any mention of anything like that. It all refers to GCVR vehicles OVER 26000 lbs. I see no mention of GCVR under 26000lbs, which I would be. If that’s the case there are one hell of a lot of guys driving illegally out there. A 10000lb – 12000lb trailer behind a pickup is a pretty common site in my neck of the woods.
john in la
03-31-2006 11:30:13
 Re: Trailer towing limits?? in reply to TSW, 03-31-2006 05:58:15
How are you going to pull a 14,000 lb load down the road; be in legal weight limits; and be under 26,000 lbs gross????? ?????
Neither of the trucks you mention can pull the load. The biggest is licensed for 18,000 lbs and just the trailer is going to weigh that much.
Your truck license/GCWR have to cover the entire weight; truck; trailer; and load.
TSW
03-31-2006 12:34:23
 Re: Trailer towing limits?? in reply to john in la, 03-31-2006 11:30:13
Easy!
I called DMV and they said I could register the truck all the way up to 26000 lbs. and still be legal under a class D license. They couldn’t care less. If the trailer weighs 18000 and the truck under 8000 you would be under 26000lbs combined. No CDL required. If what your saying is a law it must not be federal but some states. I also questioned a local and state cop and they said they would never write any tickets for it. At any rate I found someone to haul it for me pretty reasonably so I m going to let them worry about it. We rent equipment and contractors with no CDL routinely haul loads in excess of 10000 lbs. behind pickups of all kinds.
john in la
03-31-2006 14:47:20
 Re: Trailer towing limits?? in reply to TSW, 03-31-2006 12:34:23
And yes that is all true.
But I still have the question of..... ..
Is your truck rated at say 25,000 lbs.
I think to get a truck rated to pull a trailer that weighs 18,000 lbs you would need one rated at over 26,000 lbs.
Glad you found someone to do it.
KRUSS
03-30-2006 07:17:09
That question is quaranteed to get a lot of different responses on this forum. Do what you think is best and safest (just one more opinion). If you satisfied EVERYBODY you would never tow anything on a trailer anywhere.
barnrat
03-30-2006 04:46:41
I haul tractors all the time with my 99 1 ton dodge cab and chassis. The NY state DOT is really working hard to hand out tickets on any truck that looks commercial. I have a class A CDL and have the proper paperwork and DOT numbers on the side of my truck. That 3/4 ton truck would haul your rig but legaly you'd be over loaded. I'd take back roads and your credit card(DOT takes all major credit cards). Good luck.
jhill
03-30-2006 04:33:11
If your drivers license is a plain license you are limited to a 10,000 lb trailer period. DOesn't matter what is pulling it. Fines are pretty stiff if you are caught. Farm machinery is usually ignored by the cops because farmers have different limits.
TSW
03-30-2006 05:07:16
 Re: Trailer towing limits?? in reply to jhill, 03-30-2006 04:33:11
I dont believe that is correct from reading the class description on the NYS DMV site. It clearly states that I may tow a trailer over 10000lbs as long as the combined weight of truck & trailer does not exceed 26000lbs.
CNKS
03-29-2006 19:48:36
I don't know the specs on your 3/4 ton, but I doubt if it is rated at 18000, more like 15000?. If it is not rated at 18000, you are not only illegal, but unsafe. On the outside chance it is rated to pull 18000, change your registration to fit. If not put a cat 5 on your 1 ton. You can increase the rating of those hitches by using a load equalizing hitch, but you can't get a cat 3 or 4 to 18000. I don't know what a cat 5 with a equalizing hitch is rated at though.
TSW
03-30-2006 13:13:09
 Re: Trailer towing limits?? in reply to CNKS, 03-29-2006 19:48:36
Where does one find what a vehicle is "rated" at?
I know what it is registered for but what is the "rated" weight. Could it be more confusing?
CNKS
03-30-2006 13:45:37
 Re: Trailer towing limits?? in reply to TSW, 03-30-2006 13:13:09
Check with your dealer for towing capacity -- it could also be in your owners manual. My GMC half ton theoretially can pull 8700 lbs. The usual half ton registration in KS is 12000 lbs combined (trailer and vehicle). 5300 lbs truck weight + 8700 = 14000 lbs. That weight meets the manufacturers specs, but then the registration is wrong. It can be registered for 16000 lbs CGVW. Since the truck weighs 5300 lbs, technically I am legal pulling 10700 lbs -- no way I'm going to do that with only a half ton. Point is you need to know the towing capacity of your truck, plus the CGVW, and register it to whatever weight your state will let you and still be within the CGVW.
Chick
03-29-2006 19:04:22
I"d load it and go with it. Of course though, when I was a teenager, I use to load a 900 case onto a 16 foot lowboy, and haul it from field to field. The back tires centered the top rail of the lowboy.
