Tractor Talk Discussion Forum
Redundant Topic, Sorry
Allan In NE
04-03-2006 08:32:51
Hey Guys,
Hate to keep whippin' this ol' horse, but a fella from over in the middle of Iowa just told me that he used to run a disc ahead of the plow when dealing with heavy sod.
Said it will then turn better and isn't so darned hard to work down after the plow.
Any of you guys ever try this trick?
I'm really concerned with saving ground moisture and how I'm gonna get it to melt down into a decent seedbed by September given our limited rainfall.
Thanks,
Allan
WyoDave
04-03-2006 19:40:42
 Re: Redundant Topic, Sorry in reply to Allan In NE, 04-03-2006 08:32:51
Allan, we always disk plowed alfalfa ground. Than twice with the roller harrow at an angle. Plowing corn ground just the roller harrow, but in alfalfa or grass we disk it once good after the plow.
David
Allan In NE
04-04-2006 05:28:50
 Re: Redundant Topic, Sorry in reply to WyoDave, 04-03-2006 19:40:42
Mornin' Dave,
Yep, that's what I'm gonna do.
I have the disc all hooked up and ready to go. If I can finish flippin' it today, I'll smack it before it dries out and maybe I can still save some of that moisture.
I knew this was going to be a problem. Wanted to fall plow it, but ran into issues with the purchase agreement, couldn't plow til this spring and now I've got a mess.
You goin' yet?
Allan
WyoDave
04-04-2006 05:42:40
 Re: Redundant Topic, Sorry in reply to Allan In NE, 04-04-2006 05:28:50
Yep, got started yesterday. Finding a couple problems in the ole 4020. First I had to go find some more wheel weights, than a couple rounds and it was getting pretty hot. Took it to the house for a radiator flush and cleaned all the fins out. Filled it back up, and plowed till about 9 last night. Its going smoothly now. I'm having a good time. You should hurry, and get that disced and packed before this storm on Thursday rolls through. You'd be sitting pretty decent for moisture then. I was hoping to have mine done by then too.
David
Allan In NE
04-04-2006 05:56:22
 Re: Redundant Topic, Sorry in reply to WyoDave, 04-04-2006 05:42:40
Dave,
Why the heck do those old tractors always do that? Ever darned year its a session with the garden hose. :>)
Yep, I hear ya and again, you're readin' my mind. If I can beat this storm, I'm a happy camper.
Allan
Old Pokey
04-03-2006 17:47:06
 I do 80% of my top work before I plow. in reply to Allan In NE, 04-03-2006 08:32:51
Hi Allan. I dont anything about your part of the country, but here in western oregon, I do roughly 80% of my top work before I plow. After I plow, the ground lays out so well, it dont loose the moisture. I can see why you would be concerned about moisture after seeing your pictures.:-) When I have to take out a grass seed feild that is sod bound, I will rip it twice, run over it with the digger disk, then a tandem disk a time or two and finally a roller right in front of the plow. It plows over so nice. No holes, no boulders sticking up to wick the moisture out, no ribbons of roots making it extremely rough to work.
Plus the plow pulls easier.:-)
Allan In NE
04-03-2006 18:12:49
 Re: I do 80% of my top work before I plow. in reply to Old Pokey, 04-03-2006 17:47:06
Yeah, but Feller,
We've had this conversation a time 'er two before.
You're a heck of a lot smarter than I am. I'm gonna keep on keepin' on; hooked the disc up today and as soon as it is all flipped, I'm gonna give it a good whack and hope fer a good rain or two before September to bail me outta this mess.
'Taint no sense to worry 'bout it; it's either gonna fly or it won't, in which case that old field can lay there another year ifn' it really wants to. :>)
Allan
Old Pokey
04-04-2006 06:37:01
 Smarter than you??? in reply to Allan In NE, 04-03-2006 18:12:49
I sincerely doubt that part Allan,:-)
I hope the weather does what it should for you.
Russey
04-04-2006 06:31:25
 Re: I do 80% of my top work before I plow. in reply to Allan In NE, 04-03-2006 18:12:49
Allan you will surely get enought rain by September dont ya? If not, it aint a gonna grow anyway.
CBBC
04-03-2006 16:27:36
Well Allan, I think it really depands on how much you want to do. In our Fraser Vally clay loam on the coast, we do the following to break sod fields.
1 Roundup. 2 Rototill minimum one time. 3 Disk if need be. 4 plow. 5 cultpack. 6 disk. 7 pack and plant.
This is the prep for row crops peas, beans, strawberries, corn etc.
Once you get into rocky or peat soils it is a completly different game.
I also have one neighbor who only has a 6' rototiller. He just keeps rototilling until it is broken up enough to plant his 18 acres of corn.
Grant
wolfman
04-03-2006 16:10:14
With the coulters set right, the sod should roll under with only the least inch wide ripple showing. First pass with disc and that small band of sod is under. I kind of forget but I think the coulter disc is set 3/4 in out from the shin.
steveormary
04-03-2006 13:38:06
Allan, I never had much luck disking ahead of the plow. If I didnt plow in the same direction I pulled the disk the plow would plug up.
Anyway,have fun,play safe and good luck.
Now I see why you are in 3rd. I didnt know you were pulling 4/18"s.
steveormary
jhill
04-03-2006 11:28:13
Allan,
I farmed a place for a few years that was really sandy. If worked it up 2 much it would turn to dust and the crop never came upwell. I started disking it and I would half lap so all my tillage was done in 2 passes over the same spot. I pulled a packer behind the disk. The moisture never got a chance to evaporate before the packer sealed it in. I grew great corn on that ground for several years.
Jerry
John e.c.MI
04-03-2006 10:21:48
Allen, this may be one of those "here" vs. "there" things but wheat after sod is a bad idea.
Allan In NE
04-03-2006 10:33:07
 Re: Redundant Topic, Sorry in reply to John e.c.MI, 04-03-2006 10:21:48
Hi John,
What makes ya say that? Neighbors out here do it all the time. 'Course ya loose a year because of the rotation, and no, spring wheat sure wouldn't work.
There is no other option. Either wheat or right back into alfalfa. Only two things that grow out here on the desert.
Allan
Quebec Red
04-03-2006 09:54:32
Forgot to add two things First: NO question is redundant. Second: never feel sorry for asking a question. Sometimes, though, you may feel embarassed at the ideas that some poor sap has when he (I) replies (Y)!!!!!QR..
RodInNS
04-03-2006 09:50:47
Dunno Allan...
Never really tried that, seriously. With the sod we have up here, it just laughs at a tandem disc. you can drive around on it all day, and not leave a mark. I've gone in with an offset in this sod.... and there's a few zealots around here that swear by that sort of thing.... but all I've seen from it was an expensive mess. I find that in a heavy sod, the best solution is a long board moldboard plow. I know you have the short stubble plow. I've made do with that too. But really, the easiest pulling, best turning plow I've seen is Kverneland. Long bottoms, long frame, and big trash clerance. I'm pulling 4 variable 12-20's with a 70 PTO hp NH TS90 MFWD at 4-5.5 MPH. Might fall under 4 mph in heavy clay sod. The biggest problem with that plow is dead weight. It's just shy of 1 metric tonne. Which equates to 700 #'s of cast (up front) and 4 loaded tires added to a 9200# base weight tractor, just to manage the plow. Think if I was you right now, I'd just keep chugging away. You'll get there eventually. Personally, I think you have the wrong plow for the job, but ya got what ya got. BT/DT. Have fun.
Rod
Allan In NE
04-03-2006 11:26:41
 Re: Redundant Topic, Sorry in reply to RodInNS, 04-03-2006 09:50:47
Now darnit Rod,
I've been readin' you on here for years now and your opinion carries a heck of a lot of weight with me.
But I just don't see how your plow and mine can pull all the much differently.
Granted, when the heavy old sow comes up out of the ground, we sure have a handful, and we will do a two-point balancing dance on the rear tires to spin around the corner. But, while in the ground and operating, almost all the total weight of the plow rides on that gauge tire and all the tractor actually really sees is the pull of the bottoms.
Fact of the matter is, only the furrow side lift arm is used to set the front furrow depth and the only arm that actually carries any front end weight to speak of. The other arm just "floats" and carries no weight at all.
I just don't really see the tuggin' difference. Although, I'm the feller that says you can't plow with a Farmall H too. :>(
I dunno, but ain't we havin' fun. :>)
Allan
RodInNS
04-03-2006 15:03:24
 Re: Redundant Topic, Sorry in reply to Allan In NE, 04-03-2006 11:26:41
Hi Allan,
The weight I'm carrying around is basically just front ballast to keep her under control in transport. Course it helps give them fronts some traction too... Just had to give a little poke :>)
The difference in pull I think stems from the body (bottom) style. From what I've read on these fourms over the last few years, I think the body style I use is probably quite foriegn to most of you fellas in the mid west. These are Kverneland #8 bottoms, which are basically a big, wide, long slab of a board with a gentle roll. I also have an old David Brown 3x16 plow with boards very similar to your IH. The Brown had a very short abrupt board. They turn very aggressively, and work the soil over a lot more (break it up more). Also, in heavy sod, they do a good deal rougher job of plowing. They would never make the nice even tightly creased furrows (in sod) that we're used to in these parts. That's why I called it a stubble plow. Most guys only used them in vegetable operations where they were flipping it and flipping it year after year. I think tractor vet has a point too when he mentioned you had no coulters. That's just about unheard of here. Gotta have that coulter there to help with the cut. So that combination might make things pull harder. Plowing is also one job where some of the biggest gains are seen with front wheel assist. It lets that 70 horse tie that power to the ground and make a lot more of it work. I will admit though, she's bellering to do it.
Agree with you 100% on the plow settings though. The plow isn't weighting anything when it's properly set, and in the ground. I've often watched the toplink sitting slack. On the other side, I've seen ground so hard that the leaf springs on that plow were all hunched up, and the center of pull was thrown off so bad you couldn't make any kind of a job at all, and the plow just lying over on it's side. I know what t.v. means when he's talking about a wheel or 2 in the air too, and sparks coming off the boards, and warm to the touch.... in cool weather. Now what's we doin argueing over this... git back at er! Take care.
Rod
the tractor vet
04-03-2006 12:19:50
Allen there is a huge differance in the way plows pull one thing is that you do not have any coulters on that plow to CUT the sod and this can add alot of drag . and a mounted plow does pull a bunch harder then a semi mount . and like i said before on free ranged grazen land a Vee ripper would be a huge plus along with brush hoggen to grass first or a burn down with round up then let set for a week then mow it and plow it . Like around here when we chop corn on fields that are a bit on the wet side come spring if we do not get a good deep freeze and it gets to dry ya want to see a tractor work hard and have atleat one ft. wheel hangen in the air with a 1000 lbs up ft . I have seen days that it was plowenso hard that you could not touch the moldboards because they were so hot that you would burn your hand. OR spin a rear tire on the rim and pull the valve stem off the tube
J. Schwiebert
04-03-2006 09:49:34
When and what are you planting in this?
Allan In NE
04-03-2006 10:08:45
 Re: Redundant Topic, Sorry in reply to J. Schwiebert, 04-03-2006 09:49:34
Hard red winter wheat about September 10th.
Just trying to get this old pasture back into rotation/production because what hay it does produce is nothing but grass hay.
Allan
J. Schwiebert
04-03-2006 11:48:22
 Re: Redundant Topic, Sorry in reply to Allan In NE, 04-03-2006 10:08:45
Here I thought you were going to corn or milo this spring. Had a cousin in Kansas that kind of farmed like that. Here we would spray it in couple of weeks and put no till corn in. Works good if you don't get 9 inches of rain in 3 days.
Coloken
04-03-2006 09:48:53
I don"t usually even talk to people that use a plow, but this old place might might just be an exception----once. My take, just hang in there with what you are doing.
Kennyp
Allan In NE
04-03-2006 10:26:39
 Re: Redundant Topic, Sorry in reply to Coloken, 04-03-2006 09:48:53
Mornin' Kenny,
Wish you were closer so that you and I could go fer a little stroll out across this farm and I think you'd see what I'm fighting.
I've been watchin' this place for two years now and could see the potential, but there just is no getting around my having to upset the whole damned farm this season.
I never, but never under any circumstances, plow in front of oats. But, believe me, it has just got to happen this year; even on the old wheat stubble. Wish you could see it and then you'd understand where I'm standing and where my lunacy stems from.
Like you say though, give me a year down the road and I can totally park the plow except for the alfalfa ground. :>)
Allan
Wyokid
04-03-2006 09:38:37
One of my neighbors busted up some sod last spring using moldboard plow. All he did was "chisel" it like normal during the summer and plant in fall with hoe drill. Looks like he got a good stand this spring. Don't remember him b**ching very much last summer, so must work OK. BTW I'm about halfway between Cheyenn and Pine Bluffs so farming style is similar to you, I assume from the pic and you discussions you must be in the wildcat hills or near chadron somewhere.
NcNE
04-03-2006 09:30:06
Hey Allan
Don't know if this will help you out any, but when we took and converted old alfalfa ground that was let turn into pasture into a corn field we ended up running a deep-ripper through it and then hitting it a couple times with the disk. It was pretty rough when we planted the corn but after that it wasnt too bad at all. This was down here in Central Nebraska, so the soil is probably a little different. Hope this might help ya out a little bit.
JMS/MN
04-03-2006 09:00:30
There have been a few times when I ran a chisel plow ahead of a moldboard plow in really tough sod. Does rip up some of the roots to make the plow pull easier. Moisture loss is not much if you plow right after chiseling. Typical tandem disc would not cut much in sod like that, buy now I have an offset which would mulch sod in two passes.
Chad Franke
04-03-2006 08:54:26
I know you've heard it before, you need to get a blade machine instead of the plow. But if you are going to plow that pasture, I would agree, either disk it or rip it to make it easier. Either get rid of the "mat" of roots, or pre-loosen the soil.
Growing up in NE Colorado, the only time I heard anybody talk about a plow was in virgin ground, and that was rare...everyone used a blade machine, a rod machine, or occasionally a disk to incorporate trash.
VADAVE
04-03-2006 08:49:15
Around here the problem isn't dry ground it's errosion but getting new ground ready is still the same.
I usually put in no-till corn the first year which gives the grass a chance to rot a little.
Running a disc in front of the plow after corn harvest helps break up the corn stalks so it doesn't plug the plow so bad. So should be the same in sod.
Now if loss of mositure is a concern why plow? Plowed ground will dry a lot more then unplowed. Around here the Federal Conservation boys bought a no-till drill they rent to get farmeres to switch to no-till. I rent that. Sure saves the expensive fuel, time getting the field ready and in my case concern for errosion. Is there such a thing around you?
Mike (WA)
04-03-2006 08:40:58
I've seen it done out here, where the sod can be monumental. Just about have to use an offset rather than tandem disc, to get it to cut enough. A regular tandem disc will just ride along on top and do little damage to the sod.
Quebec Red
04-03-2006 09:23:57
  Allan in NE in reply to Mike (WA), 04-03-2006 08:40:58
I think that since you are well advanced in the plowing, and time is crucial, I would continue as you are doing. Regarding moisture, pulling a packer on your last tillage pass, and behind your seeder will defineatly improve the moisture situation. Even here in Quebec this is a common practice. As well, the field is much much smoother, and small stones are no longer a problem. HOWEVER, Allan: I am very concerned about your 966. You state that there is a noise in the driveline. Possibly from sitting, possibly not. (wear?). You are often in 3rd with the Big Stick back and the 414 set at maximum howl. IH plainly stated not to work the tractor in a pull situation requiring a speed inferior to that of 3rd Big Stick forward. (And I quote from the Holy Bible, as written by IH) I strongly suggest (even insist) a little air wrench modification to remove the last furrow. With the increased forward speed, you will do as much work in an hour, and not be required to make a large involuntary contribution towards the benefit of CNH. I have seen too many rear end problwms caused by maximum sustained pulling at too low a forward speed. Combine that with the weight of the plow, turning stress, little slippage, etc. Everything you do not want is there. While I am on the subject the similar situation presents itself with the 686. The 18.4x38s are too much tire for the tractor. The gear ratios are not matched for those tires. A maximum size would be 16.9x38 bias dry. Again the radial tire will put too much strain on the old Farmall M diferential. And I know full well that those 310s will pull their heart out ( along with the trans and rear end). And there are 18.4 duals on the 686..... .....For anything other than light work requiring flotation, and even then-NO. I am not trying to be a smart-ss or hogging the board with my opinions. It is just that I have been there, done all that, have all the medals (shop bills..) that proved that Father IH was right, and that QR was wrong, expensively wrong. This is just my experiences over many years of trying to get one under the wire too often..... .QR.. and others can provide similar testimony in front of the judge....
Allan In NE
04-03-2006 10:04:18
 Re: Allan in NE in reply to Quebec Red, 04-03-2006 09:23:57
Hi Red,
Bless yer heart, if you guys didn't watch out fer me who would? :>)
I think the old 966's rear end troubles are on the wane (crossed fingers). I lifted the plow out of the ground an inch, which puts me right at 9" and that got me to 4.3mph, 3rd, forward stick. It's going pretty darned good with the exception of a tough spot every now and then.
This dryland farming is kinda throwin' a few curve balls at me, but I think you guys are right. I watched the neighbors last year and they just barrel into it with the plow and use a disc as a first pass behind after the first good rain. Then, it is just a matter of summer fallowing as per usual the rest of the summer with the spring tooth or a cultivator.
The 10 acres I got plowed last fall with fall right into line with just a pass of the packer 'cause it is mellowed out now.
Don't know 'bout that 686 thing. In 1980, the 18.4s were an option as far as I can tell. ??
Allan
Dr.EVIL
04-03-2006 10:47:01
 Re: Allan in NE in reply to Allan In NE, 04-03-2006 10:04:18
Allan - 18.4 X 34's were the option. Not 18.4 X 38's. The parts were there to even put 20.8 X 38's on them but that wasn't available.
Allan In NE
04-03-2006 10:51:03
 Re: Allan in NE in reply to Dr.EVIL, 04-03-2006 10:47:01
Aw Ha!
That's why I have to gear the old pig down. She just walks way too fast. 2nd gear feels like 3rd ought to. :>(
Always did think those tires were way too darned big.
Thanks Pard,
Allan
hayray
04-04-2006 04:25:45
 Re: Allan in NE in reply to Allan In NE, 04-03-2006 10:51:03
Allen,
I must have mis-understood your post last week when we were conversing bout the cultimulcher, I thought you did not mould board?
Last time I tried to disk before I plowed it created a real mess with trash build up. However, when I used a IH 710 5 bottom, that has a lot of clearence and long distance between bottoms and handled trash real well. Would a chisle plow work for what you do, that is all I use now as far as digging up roots, but if you want to save moisture and summer fallow why not just use round-up and a disk?
Ray
Allan In NE
04-04-2006 05:18:47
 Re: Allan in NE in reply to hayray, 04-04-2006 04:25:45
Hi Ray,
Appears pretty "flip-floopy" don't it? :>)
Normally, and if I could have been lucky enough to have gotten this patch fall-plowed, I wouldn't even be thinking about it; I'd just run the packer over it and be done with it.
Without publicly going into details tho, there were some issues with the purchase agreement and I wasn't able to plow this field until this spring because the prior operator's hay stacks didn't get removed until just a few weeks ago.
So, here I set with a "slabby" mess and it looks like the disc is going to be the only option if I wanna get it cut up and worked down this summer.
I've plowed a lot of sod, but this root infested, cattle tromped pasture is the worst I've ever ran into. So, I'm gonna give your method a trial and hope beyond hope that I luck out and get a rain on it to help melt it down before September.
Allan
Quebec Red
04-03-2006 12:25:30
Went all through the trans and diffy of a F656 that I bought that had 18.4s38s. When I was finished, that tractor had 6.50x16s and 15.5x38s making her level. Cranked the Roosa to 2400, and got my highway hot rod speed back!!!!!, and with those tires, she kept it there. With the 18.4x38s, even a fart in the wrong way would slow it down. Pretty much redid the tractor from flywheel back. Mucha $$$. Luckily, when I bought it,I had a good idea what was needed, and priced accordingly. Still was stupid of the previous owner to willfully set himself up. Now that you can pull in 3rd with Mr. Big Stick reaching for the radiator, you will be at the limit limit ( I know that there are two limit words....) of what you may pull, change the transmission oil and filter after working this spring to remove the rust and varnish and other crap that will have come off the gears etc. and are in suspension. Keep us informed...QR..
Harley
04-03-2006 09:38:14
Like Red says, you are far enough along now, you just might as well bite the bullet and git er plowed. The disc works well over cornstalks to chop them up so they don"t plug up a moldboard plow, but on sod your disc won"t do a thing but make ya feel like you"re doing something. You just plain have to get those old 1/2 inch alfalfa roots cut and plowed under. Harley
