Tractor Talk Discussion Forum
International 300 Utility
jenglin34
04-03-2006 18:42:13
I recently purchased a IH 300 utility. It came with many extras but the power steering is not working nor is the PTO. Any suggestions??? There is a clear fluid leaking under the steering column what that is exactly I'm not sure. How do you check the fluid in those things? Also, I pull on the hand lever for the PTO and I can't get it to engage. Does it need to be in gear in order for it to work or does something need to be adjusted on it? Any suggestions would be helpful. Thanks alot, Jim
JAS,Tn.
04-03-2006 19:58:59
 Re: International 300 Utility in reply to jenglin34, 04-03-2006 18:42:13
Great site is it not have been monitoring it for a while.If you have a IPTO Look under the front of trans .There is a small lever that disconnects the PTO from engaging.this was if you were going to ride alot with out using pto or for on road driving. saves on the gears . If that does not do it then it could be internal or the lever out of adj.That is what I have found on mine. i just had to replace the PTO drive and clutch and pressure plate and the seals involved. Not sure about your steering problem,I have manual.
good luck
John
TDK
04-03-2006 18:52:59
That's most likely hyd. oil leaking. The power steering uses the oil from hyd. system and there's a plug you can unscrew under the seat cushion to check hyd. level.Does your 300 have independent or trans. driven pto ?
jenglin34
04-03-2006 18:55:24
 Re: International 300 Utility in reply to TDK, 04-03-2006 18:52:59
I would assume an independent pto, I'm not for sure. I'll check out the plug. Thanks
TDK
04-03-2006 19:47:33
 Re: International 300 Utility in reply to jenglin34, 04-03-2006 18:55:24
Jim, the IPTO is engaged by a long lever on the right side of seat. Trans. driven is engaged by a rod behind seat near rockshaft.
