Tractor Talk Discussion Forum
JD 440ID Hydraulic Pump
Mike Wren
04-04-2006 10:39:08
I have a 440ID with a cessna 2015-1faa hydraulic pump on it that is dying...Deere and Cessna are saying obsolete on the pump rebuild kit...1. Any suggestions on finding a kit? 2. Does anyone know the pressure and volume of that pump or the 440ID system to possibly figure out a replacement for it if I can't hunt down the kit?
buickanddeere
04-04-2006 13:24:12
 Re: JD 440ID Hydraulic Pump in reply to Mike Wren, 04-04-2006 10:39:08
I assume this is the aux hydraulic pump which is mounted infront of the tractor and driven off the end of the crank? Any old generic pump with the rated volume & capacity from a hydraulic parts vender. Will bolt on and work fine. Seals and bearings are generic and most can be subbed at a good parts supplier. If the pump is gear style then just refacing the side plates, rotor & body to restore clearances works well enough.
