Tractor Talk Discussion Forum
Rototiller Recommendation
Russ(Bolivia)
04-04-2006 11:27:17
I’m looking for a three point rototiller about seven feet long (need to cover up my tire tracks). It needs to have gears (not chain) drive and be heavy enough to handle cutting 14 acres at a time. I don’t want an off-set type.
The tractor it will be used on is a JD 5310 (55 PTO HP).
I think I need a single speed one with ability to dig eight inches deep. I will use it in a heavy soil (lots of clay).
I have seen a lot of advertisement about Howard rototillers and about how tough they are. I saw a huge one at the Agricultural Fair in Raleigh, NC a few months ago and was impressed. I don’t need anything nearly that big, however.
I would like to Buy American. I have looked on the Howard Web site (http://www.howardrotavator.com/), but I have a problem with them: they are not American made, they are now made in Denmark (I think).
I have also seen a lot of postings about King Kutter, but they only go up to six feet.
Can anyone provide any suggestions based on machines they own?
David Kronwall
04-05-2006 04:07:15
 Re: Rototiller Recommendation in reply to Russ(Bolivia), 04-04-2006 11:27:17
I can tell you a little about Howard Rotavator, because I worked for them from 1979 til 1985. I was their ad manager and wrote/photographed their brochures and sales literature. Howard was a worldwide company headquartered in England. They called their rotary tiller a ROTAVATOR (which, by the way, is a palindrome--a word spelled the same way forward and backward), because ROTA stood for "rotary" and VATOR stood for "cultivator," since the Brits refer to tillage as cultivation. It's a registered trademark.
The ROTAVATOR was designed by A.C. Howard, who developed the scroll-pattern of the blades along the rotory shaft, powered by the tractor PTO. A.C. was a contemporary of Henry Ford, and I'm told, he and Henry--both tinkerers and inventors at heart--used to correspond and compare notes.
Howard's USA headquarters was in Harvard, IL, when I joined them. We had a manufacturing plant in Muscoda, WI, where we built small ROTAVATORS like the Model HN and HJ--suitable for small, garden-type tractors. We also built a large, wide seedbed tiller called the Model HW ROTASPIKE. The rest of the ROTAVATOR line--designed for the horsepower you're using and higher--has always been made overseas. Some models were English, some French, some German.
ROTAVATORS have always been rugged, well-designed machines. They are, however, quite heavy and do require substantial horsepower. I don't remember specifics, but I agree with what dhermese and Tramway guy have indicated--they do require power and, depending on your soil, 8" of depth might take either a slow, slow forward speed or multiple passes.
Unfortunately for a lot of us, Howard closed their USA facilities in 1985 but continued to be made overseas. The company was purchased I think in the late '80s by the Danish giant Thrige Agro, which made a full line of ag equipment. ROTAVATORS continued to be sold in the states by distributors, and they still are.
Apparently the line has been acquired by Klonskilde (not sure of the spelling), the people who make chisel plows and other tillage equipment. As far as I know, they are still handled by the same distributors around the USA. I guess they have changed the good ol' Howard orange for Klonskilde red, but the machines are still being built.
Russ(Bolivia)...I'd recommend locating the Howard Rotavator distributor in your area and checking them out. If you're not sure who that is, you might contact the distributor I know in Illinois--Guy Farm Machinery in Woodstock, IL--and ask Clyde who your distributor would be. Tell him Dave sent ya.
David
coup
04-05-2006 03:18:09
i have a yearning for a tiller also..... you can set your wheels in,when plowing... they say that plows and disk are alot more economical. 14 acres would be a lot,,,for a tiller but i am just a small timer from wv....if i could afford a 60inch tiller....i would use it for .5 acre garden spots and food plots.. if using on plots way back n the hills i would spray grass and save two trips back on the hill by using tiller.
John (MO)
04-04-2006 12:14:09
Don't know anything about a Howard, but I am sure you don't have enough tractor to till 7 foot wide by 8 inches deep. You need a plow and a disk.
dhermesc
04-04-2006 13:15:11
 Re: Rototiller Recommendation in reply to John (MO), 04-04-2006 12:14:09
I agree, 7' foot tiller set 8" deep, better have creeper gear and a lot of patience.
Tramway guy
04-04-2006 12:02:20
Howard made a really good machine. My brother had an 80" model, used it on a JD 3020. Could have used a bit more power though. I think that Howard recommended 1HP per inch of width. But that machine was awfully heavy compared to the much lighter duty machines of today. The Howard had a chain drive, but it was correctly engineered and applied and ran in an oil bath. Absolutely no problems with it, ever.
