Tractor Talk Discussion Forum
Adhesive for cab interior
Formerly PaMike
04-04-2006 16:59:43
What do you guys use to reglue a cab interior? Just regular 3M spray adhesive? I have used 3M adhesive before on other things and it doesnt seem like it would be strong enough.
Thanks
Dave from MN
04-05-2006 03:48:21
 Re: Adhesive for cab interior in reply to Formerly PaMike, 04-04-2006 16:59:43
Where are these cab interior kits from and do they have specific kits or are they one for all its?
JMS/MN
04-05-2006 18:36:02
 Re: Adhesive for cab interior in reply to Dave from MN, 04-05-2006 03:48:21
Fehr Cab Interiors- IL or IN? Kits about $140 for Deere, others available, pre-cut. Adhesive included- very good stuff. JD dealer might have the same stuff. One inch foam available by the foot or yard- I bought a pre-cut kit for 4020- everything fit well, was well worth it. Google search or Fastline Mag..... ..... just checked my desk list- Fehr is at 1-815-692-3355. Fairbury, IL.
davpal
04-04-2006 21:34:07
Wal-Mart sells the big can of 3M foam adhesive for about $8 bucks a can. It is a big can. I used two full cans to glue a new cab kit into a 4-150 white and it took almost every bit of it to do the job right. Don't worry about the stuff being strong enough, it is. Just worry about getting the piece in the right place the first time because this stuff is so tacky you will never budge the piece without ruining it. It worked flawlessly.I also used it to glue some heat resistant foil foam to the front of the fuel tank. Good luck.
Glen in TX
04-04-2006 21:16:12
3M and others make different kinds of spray adhesives and get the one for foam or vinyl depending on which on you need. NAPA or local body shop paint stores should have it and know which one you need. Can get it in cans to brush or roll on also.
Hurst
04-04-2006 19:16:53
There is a special cab adhesive that 3m makes and some other companies too. I think they even sell it on this site. I would check with your local tractor dealer, they should be able to hook you up with a can or 2. TSC may even carry it. It wouldn't hurt to give them a call about it. Good luck
Hurst
