Tractor Talk Discussion Forum
Re: Loading a dead tractor
Ol Chief
04-04-2006 20:29:30
This past week I loaded two Case 900B diesels. One on steel wheels.The other had huge rice tires with about 1100 lbs.of cast iron on each back wheel plus front weight.Then loaded loaded a MM BI 445 and a Minne Mo M5.I used three snatch blocks and 150 feet of one half inch cable and a 45 hp MM 445.Probably could have used one of my 335"s,lt went so easy with 3 pulleys.I anchored the head block to the gooseneck ball,second block to tractor axle,tail block to forward trailer side frame.They all went on so easy,but getting off was hairy because I did not use any restraining method.
