Tractor Talk Discussion Forum
Jubilee leaks fuel
Bob T.
02-06-2006 21:02:19
I have a ford jubilee that leaks fuel out of the bottom of the carb. I recently rebuilt the carb including a new float. I adjusted the float to 1/4 inch like the book said. It still leaks. What else can I do?
old
02-06-2006 21:25:17
 Re: Jubilee leaks fuel in reply to Bob T., 02-06-2006 21:02:19
If the new needle is a rubber tipped type, open it back up. Pull the float back off and then drop the needle in the seat after makeing sure the seat is good and tight, if the seat is loose it will cause your problem also. With the needle in the seat use a small hammer or end of a punch etc and tap on the needle a ouple times. What that does is sets the tip of the needle in to the seat. Got that from an old carb guy that is long since gone.
