Tractor Talk Discussion Forum
Generator repair, 1000 watt
Mike S 806/H
02-10-2006 16:43:17
I have a Nissan 1000 watt generator, There is a part that I need Im going to guess its a voltage regulator? it has numbers on it 18.0uf+-5%, 220vacm, SHW-S 84 it about 1 x 2 inch box with 2 male flat pin connections on it, where can I get one, this one melted and cant find Nissan parts, Any Ideas?
KEB
02-10-2006 17:52:14
 Re: Generator repair, 1000 watt in reply to Mike S 806/H, 02-10-2006 16:43:17
Radio Shack won't have anything lke that - their parts selection stinks, plus I have yet to run across a clerk that actually knows anything about parts. Getting to be almost as bad as some of the chain auto parts places.
18 uF is a capacitor value, 220 VAC is its operating voltage. Other numbers are probably the manufacturer's part number. Best bet is a motor starting capacitor. Not sure what it would be used for on a generator, but capacitance value typically isn't real critical as long as the operating voltage is at least as high as what's marked, so if you can get close go ahead at try it.
If you're near a big city, try a place that re-winds electric motors. Otherwise, an industrial supply place, either local or mail order, is probably your only other option. An electrical supply house or an air conditioning repair place might have something similar.
Any idea why it fried? Capacitors have been known to self destruct, but it doesn't happen very often. Overvoltage condition, maybe?
Keith
Mike S 806/H
02-10-2006 17:59:33
 Re: Generator repair, 1000 watt in reply to KEB, 02-10-2006 17:52:14
Hi, Keith I have no idea why it fried? It melted the inside, looks like aluminum in there, I may have over loaded the generator? I had a TV/VCR and a box fan running from it.
KEB
02-11-2006 12:29:17
 Re: Generator repair, 1000 watt in reply to Mike S 806/H, 02-10-2006 17:59:33
Mike,
I don't think a TV/VCR and a box fan would be any where near full load for a 1000 watt generator. In fact, consumer type generators often work better if they're loaded close to capacity; better quality power and better regulation.
If it were mine, I'd look carefully at the generator windings to see if maybe something shorted. Look for a spot that looks overheated. Too much current through the capacitor could cause it to overheat.
If you don't see anything, you could try replacing the capacitor & see if it works. Just don't plug in anything electronic like a TV until you're sure its working properly. An electric heater makes a great load for testing, otherwise plug in a couple of light bulbs. Bulbs are a lot cheaper to replace than a TV if it still doesnt' work right.
Good luck,
Keith
old
02-10-2006 17:00:07
Take those numbers to a good radio shack or TV repair place/ motor repair place and they should be able to help you
CNESLER
02-10-2006 16:53:20
I think that is a capacitor and you can get one at most appliance repair parts stores like
Grainger, Johnstone or air conditioner parts
supply places.
Good luck
CNESLER
