Tractor Talk Discussion Forum
Need info on Herucles egn.
newriverboy
02-10-2006 21:21:42
Trying to get my 1935 Silverking running and need some info on the Herules eng. Also need parts for my tractot Tks Roy
Larry from MD.
02-11-2006 09:32:34
 Re: Need info on Herucles egn. in reply to newriverboy, 02-10-2006 21:21:42
What info do you need?A 35 should have the IXA engine,but they did switch to the IXB later.Both engines are much the same with the IXB haveing larger pistons.Do you have a 3 or 4 wheeler?
newriverboy
02-11-2006 15:31:42
 Re: Need info on Herucles egn. in reply to Larry from MD., 02-11-2006 09:32:34
I have a four wheel with solid cast wheels manufactured by Pacific Axle & Trailer Equip Los Angles Calif. It is believed this tracto was used as a tug at an air field. I don't know how to identify the eng as an IXA or IXB. I would like the eng. specs. and tune-up info. I'm not sure if I have the correct carb, but I did have it running. I also need a manifold, air cleaner, muffler and carb linkage. Do you know where I might be able to locate Silverking parts? Any help would be greatly appreciated. Tks Roy in Phoenix,Ariz.
newriverboy
02-11-2006 15:31:13
J. Schwiebert
02-11-2006 17:41:01
 Re: Need info on Herucles egn. in reply to newriverboy, 02-11-2006 15:31:13
I can help you with the first two for sure and maybe more but I need a U. S. mail address.
