Tractor Talk Discussion Forum
8n
roy hill
02-12-2006 09:47:22
i have ford ser#^^8n46533^^ (^^is used for diamond.) am i correct that this is a 1952 8n with cast iron? the tractor is blue and gray sshouldnt it be red gray? ty for the help... thinking about buyiny this unit for 1000.00 it runs but smokes a bit is that a good price ty
Jim.UT
02-13-2006 08:35:33
 Re: 8n in reply to roy hill, 02-12-2006 09:47:22
$1000 for a running 8N is usually a decent price. The real question is how much are you looking forward to doing work on it? You already know from the smoke that an overhaul is in your future.
The 2N in this picture is one I bought last week for $600. It doesn't run, but the engine is not stuck. I think I can get it running with a carb rebuild, some new wires and a tune up kit. But I might wind up with the same tractor you have...i.e. one that smokes. We'll see.
third party image
roy hill
02-18-2006 08:14:59
 Re: 8n in reply to Jim.UT, 02-13-2006 08:35:33
thanks jim for the info
Coldiron
02-12-2006 18:18:10
With that number she should have a front mount distributor to make her a 1948 8N. The 48`s were from 37908 up to and including 141369 serial numbers. At 1K I would buy it in a minute if she is all there.
RJ-AZ
02-12-2006 16:19:25
There was a fad in the 60's to paint these tractors in the blue and off white of the current production of Fords then.Some dealerships would make a smokin' deal on a refurb like that t keep the shop work load up. So you can't tell much by the color.
Roger in Iowa
02-12-2006 14:28:36
The tractor should be red and tan or whatever, not gray. It might have an 8N engine but really a 9N rest of the tractor. Go to the 8N group and determine what you have. Rear hubs tell difference between. 2N's and 9N's have large bolt circle holding "dish" to the axle.
Roger in Iowa
