Tractor Talk Discussion Forum
Hey Allan
Keith-OR
02-16-2006 06:21:09
Allan, is this the same pump you have on you tractors. If so do you know what brand it is....
Thanks
PS. Watching weather report this morn, looks like you are going to get cabin fever...:>)
Keith & Shawn
third party image
dennis in or
02-17-2006 08:39:12
 Re: Hey Allan in reply to Keith-OR, 02-16-2006 06:21:09
Ha keith , ok its been fun , you can turn the heat back up now, oh, turn that windmill back down to low too
Allan in NE
02-16-2006 06:26:47
Mornin Keith,
Take the seal measurements and then go after a Farmhand pump seal kit. Sure looks like it, anyway.
Front and back seals should be the same.
Allan
Keith-OR
02-16-2006 08:02:48
 Re: Hey Allan in reply to Allan in NE, 02-16-2006 06:26:47
Thanks Allan, I will see if I can get kit today.
Then repair mounting mess, Durn shame that the only way to remove pto pump is to cut off cobbled up mounting with a hot wrench. I guess they figure , what the heck don't need to ever remove the pump!!
Again thanks for the info.
PS. will be thinking about your cabin fever as I run around outside in a T-shirt....(only in my wildest dreams) :>) :>)
Keith & Shawn
Allan in NE
02-16-2006 07:44:13
Hey Keith,
Pull the pump and see if you can get a number off that front seal.
Allan
Keith-OR
02-16-2006 08:05:21
 Re: Hey Allan in reply to Allan in NE, 02-16-2006 07:44:13
Allan, already looked at front seal....NO numbers
Keith
CRUSADER
02-16-2006 10:49:17
 Re: Hey Allan in reply to Keith-OR, 02-16-2006 08:05:21
In your travels looking for a repair kit for that pump, have you tried any of the bearing houses yet? I used to be able to get just about any seal or bearing that I needed from the Midcap Bearing, Purvis Bearing, or King Bearing companys. Just my idea or thought that you might also consider for a source for parts for your pump.
Jim
