Tractor Talk Discussion Forum
Clark forklift starter removal
hogman_2002
02-16-2006 20:48:38
I got a GCS25 Clark forklift that needs the starter taken off. What's the easiest way to get it off? It's on the right side and looks like it's not the easiest thing to get out.
hogman_2002
02-17-2006 07:41:12
 Re: Clark forklift starter removal in reply to hogman_2002, 02-16-2006 20:48:38
Thanks for the help. We bought a GCS25 about 3 months ago. It needs a motor overhaul but it does have a 188" mast. The price was right too at only $100. Then the other day we found another GCS25 for the same price but in better condition. This is the one I need to take the starter off of. And yes, everything is oily. Is it ok to use a pressure washer to clean everything off? Also where can I get a overhaul kit and tech. manual for the Mitu. motor? I got a tech. manual for the GCS but it doesn't go into detail about overhauling a motor.
Thanks
tony weir
02-17-2006 12:39:48
 Re: Clark forklift starter removal in reply to hogman_2002, 02-17-2006 07:41:12
Local clark dealer can or has manul for lift still can get it from clark and can get parts or from smh a forklift jobber your lift has a 4g52 or 4g54 mitsu it is just like a 2.4 litre in a dodge k car the manual is part no sm-520r this has all the specs you need and detailed pictures and part break downs. Its ok to wash lift but put a bag over dist and remove ign wires we wash them with kleenflo kf425 engine shampoo and hot water the worst oil leak is probarly from hyd valve the leak like a seive andthe can be fixed with oring in standard kit or at hyd shop good luck
tony weir
02-17-2006 02:34:31
the clrk gcs with the mitsu motor you need alot of help it is all ways full of oil as the hyd valve always leak you need a long ext bar and a 14mmdeep socket with a flex socket no trick just some one to hold starter i work for a clark dealer here in canada change one about every week starter is stock in service truck in fun to change one when its 25 below 0
benny2
02-17-2006 00:18:56
 Just remove the bolts!;)) Re: Clark forklift start in reply to hogman_2002, 02-16-2006 20:48:38
Hey sorry to be snyd but there is nothing easy on a fork lift and a guy just has to fight it. I have had FrkL with starters harder to take off than to just take the whole engine. Been there done that ;((
