Tractor Talk Discussion Forum
boot or vulcanize a cut tire??
Andy2
02-17-2006 10:01:41
I just picked up a matched used set of rear tractor tires. They looked great until I unloaded them and noticed a cut about 2" lon in the center of the tire where the lugs meet. Should I make my own boot and glue it in somehow or take it somewhere and have it vulcanized? Is there a premade boot that you can buy? thanks.
Leland
02-17-2006 19:21:38
 Re: boot or vulcanize a cut tire?? in reply to Andy2, 02-17-2006 10:01:41
A better idea have the wound sectioned this is better that any boot or patch most tire shops know where to send them for this repair .
Tire Doctor
02-17-2006 19:30:55
 Re: boot or vulcanize a cut tire?? in reply to Leland, 02-17-2006 19:21:38
Section repair and vulcanized are used to mean the same process. The damaged section is cut out of the tire and raw rubber is vulcanized into the hole and then a large boot is glued on the inside of the tire for strength.
Leland
02-17-2006 20:04:23
 Re: boot or vulcanize a cut tire?? in reply to Tire Doctor, 02-17-2006 19:30:55
Oh
old
02-17-2006 10:30:38
They make boots for that type of repair. They come in sizes like 2X2, 4X4, up to around 12X12 but the problem is the cords will still be showing and that makes for the tire drying out in that area. If you can have it vulcanized
Tire Doctor
02-17-2006 16:39:49
 Re: boot or vulcanize a cut tire?? in reply to old, 02-17-2006 10:30:38
Yeah, what Old said, have it vulcanized. Where the cords are cut they will keep tearing, but that isn"t too bad a cut in that part of the tire.
